20 Most Recent Sony DVP-NS508P/S DVD Player Questions & Answers
if you cant open the tray even if it is on, use a needle to **** the small hole just on the right side of the player...
Sony... | Answered on Sep 13, 2011
Could be the spin belt inside (little black rubber on motor that spins the cd) that is dirty or broken
Sony... | Answered on May 11, 2011
U hook it up wih a AV RCA R,Y,W cable change the cable or u used a HDMI cable,change another HDMI cable to another tv HDMI hub.
Sony... | Answered on Jan 29, 2011
Normally there is a manual release on the underside a slotted hole slide the arm across to open the tray.
Sony... | Answered on Oct 01, 2010
possible control board overheating or video board look for capacitors swelling on boards
Sony Televison &... | Answered on Sep 19, 2020
If your Sony remote control is compatible with your RCA TV, it will contain the applicable code(s).
3 blinks is a error code "lamp door not properly closed" but what it really means is the lamp door is warped from heat from the lamp.
The door if removed has a plastic peg on its back side-the peg when door is in place engages a tiny lever behind it----
What to do?
Remove door and engage the lever with something not metal==turn set on and if it comes on you know the door is the issue.
DO NOT LOOK DIRECTLY AT THE LAMP- DO NOT OPERATE SET PROLONGED TIME WITH DOOR REMOVED OR COVERED WITH ANYTHING ELSE==THIS IS ONLY TO SEE IF THE DOOR AND SWITCH ARE YOUR PROBLEM.
SD TECH
Sony Televison &... | Answered on Sep 16, 2020
An almost complete guess that you are feeding digital into a tv that is incapable of processing it.
HDMI is digital only and an adaptor lead won't convert the signal to analogue. Digital to analogue converters are available but how successful they are I have no experience...
Sony Televison &... | Answered on Sep 10, 2020
Sony DVP-NS508P/S DVD Player Logo
Popular Tags
20 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
unlock tray
  • Televison & Video
