20 Most Recent Sungale PD701 7 in. Portable DVD Player with Screen Questions & Answers
Think the batteries are dead in my 701 sungale
http://www.sungale.com/Download.htm Here is a link to you manual
9/3/2009 7:41:57 PM • Sungale PD701 7... • Answered on Sep 03, 2009
Keeps sayin wrong disc
If your device is a new one, it should be a factory error. You should return it back to the supplier. However, if the device just developed the fault, I will suggest 2 basic faults and their solutions:
1. As a result of insufficient or too much electric power for use by your device. You should make us a stabilizer or a step-down device.
2. As a result of a faulty lens, which is usually the major in most cases. If after trying step one it continues, then I must say that your lens has some questions to answer,hmmm. Hope this helped.
4/21/2011 7:33:35 PM • Sungale... • Answered on Apr 21, 2011
0answers
I have dvd2026.the door will
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer. Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6/9/2010 9:57:29 PM • Sungale... • Answered on Jun 09, 2010
Can you tell me where
Here you get the battery for $25. If it is not in stock call them.
8/30/2008 12:26:42 PM • Sungale... • Answered on Aug 30, 2008
3answers
AWA TV keeps asking for a password
What is the model number?
1/30/2023 3:00:59 AM • Televison &... • Answered 1 hour ago
How to rewire Delta AP 400 dust collector to 220 Volts
To rewire a Delta AP 400 Dust Collector to 220 Volts, you will need to obtain the right wiring and circuit connectors. You may need to consult an electrician or technician to complete the job safely.
1/30/2023 2:56:15 AM • Televison &... • Answered 1 hour ago
Have a Diehl Controls PCA from Ikea dishwasher with blown R513. Any idea what value this was? Diehl Controls PCA but only markings are: 771 359 CTI o S1600.
It looks like the R513 on the Diehl Controls PCA is a 4.7k Ohm Resistor, according to the Ikea service manual. I suggest double-checking this information with the manufacturer or a qualified technician to confirm it is correct. If you do need to replace the resistor, be sure to use one with the same specifications as the original in order to ensure it will work correctly.
1/29/2023 11:31:26 PM • Televison &... • Answered 5 hours ago
How much does the Vistron ltm-2671e weigh please.
This is not a make that I know in North America? I can only bring up links for parts and stands / wall brackets. This link should find it, and may work better where in the world you live. https://www.google.com/search?q=vistron+ltm-2671e+weight or 'Specs' https://www.google.com/search?q=vistron+ltm-2671e+specs ..
1/29/2023 10:35:10 PM • Televison &... • Answered 6 hours ago
2answers
DVD player is attached to tv but the tv screen is black with a box saying no video available
Is the DVD player connected to the television via an HDMI cable? You have to click Source or Input on the remote to move to that Socket.
1/29/2023 6:43:53 PM • Televison &... • Answered 9 hours ago
How to fix error 1 code on brb5200
Potential solutions for resolving error code 1 on a BRB5200 oven include:
  1. Verifying the wiring - Ensure that the wiring for the temperature sensor is properly connected and without damage.
  2. Testing the sensor - Use a multimeter to measure the resistance of the temperature sensor. If it's not within manufacturer specifications, the sensor may need to be replaced.
  3. Resetting the oven - Disconnect the oven or turn off the circuit breaker for 30 seconds and then turn it back on. This may solve the issue.
  4. Consulting a technician - If the above steps do not resolve the issue, consider reaching out to a professional technician for diagnosis and repair.
Note: Please refer to the oven's user manual for specific guidance, as the steps to resolve error code 1 may vary based on the oven model.
1/29/2023 6:28:07 PM • Televison &... • Answered 10 hours ago
2answers
How do you clean a laser on a DVD player
Clean the laser lens on a DVD player by following these steps:
  1. Turn off and unplug the player
  2. Find the laser lens and clean with a soft, lint-free cloth (no liquids/chemicals)
  3. Gently wipe lens in circular motion to remove dirt/dust
  4. Reassemble and plug in the player
  5. Test player to see if cleaning improved performance Note: Consider professional or manufacturer assistance if problem persists.
1/29/2023 10:40:34 AM • Televison &... • Answered 18 hours ago
Screen not working, replaced boards, now I've got white horizontal lines?
If your screen is displaying white horizontal lines after replacing the boards, it is likely that the new boards are not properly connected. Make sure that the boards are securely connected to the screen and that the power switch is in the "on" position. If the problem persists, you may need to replace the boards or contact the manufacturer for assistance.
1/29/2023 7:04:42 AM • Televison &... • Answered 21 hours ago
Sungale PD701 7 in. Portable DVD Player with Screen Logo
3 questions posted
Top Sungale Televison & Video Experts
ray gallant
Don A
Don A
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sungale Televison & Video
Most Popular Question
think batteries dead in 701 sungale
  • Televison & Video
