20 Most Recent
Motu 896HD Sound Card Questions & Answers
How can I get a processor of motu 828 mk3 hybrid for repair?
Puede encontrar procesadores de Motu 828 MK3 Hybrid reparados en l?nea. Existen varias empresas que ofrecen reparaciones de Motu 828 MK3 Hybrid, as? como tambi?n piezas de repuesto. Estas empresas generalmente ofrecen garant?as para todos sus productos, as? como tambi?n asistencia t?cnica. Para obtener m?s informaci?n sobre c?mo obtener un procesador de Motu 828 MK3 Hybrid para su reparaci?n
Need to know which way round LED ribbon connector goes - motu HD192
Note the wire towards the top in the picture has marks on it? That goes to pin #1. Look closely at the pins you are going to put it on. There will be some indication that one end is different, perhaps a "1", or something else. I can't see it well enough in the picture to tell you, though.
Using MOTU Midi Express XT.
Try to use the WCPCI's MIDI ports
MIDI Set-up
To use WCPCI's MIDI ports, you must enable them in two places. First, go to the System tab of the WCPCI control
panel, and set the Midi Mode to "2x2". Reboot your computer for the change to take effect.
To enable the WCPCI MIDI ports in Cakewalk, select "MIDI Devices" from the Options menu, and click to highlight the
"WC/PCI 1" and "WC/PCI 2" ports for recording (input) and playback (output).
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
