20 Most Recent
AudioBahn DUB200 Car Subwoofer Questions & Answers
Como conectar las dos bobinas
Hola angel1781,
Las bobinas se pueden conectar en serie, que los resultados en dos veces la impedancia de una bobina, o paralelamente, que parte en dos la impedancia.
Vea los esquemas eléctricos aquí. Seleccione el cableado de la bobina que da lugar a una impedancia por lo menos tan arriba como sus ayudas del amperio. Más arriba es ACEPTABLE, más bajo no está.
http://www.kicker.com/dvc_wiring
Espere que esto ayude.
Speaker asizes
There are no specific specs for a speaker box. As long as your speaker fits, and you get a screw in every hole when securing it your ok. Just remember this... The bigger the box the more bass. ( Up to your speakers capabilty )
I need to know how much airspace my 10" DVC audiobahn speaker requires
what type of audiobahn sub is a critical and missing factor of your statement so the specs im about to give you are very generic and can vary because like i already said i need to know the model number to be precise
it should be at 0.6 -2.35 and vented for the aw1005n this specification is for that sub only and depending on what kind of music you listen to will help decide the airspace u need if u get that model number let me know
I need help
Put this in google -- ported box software
Now, you will need multiple specs for your subwoofers to figure out the correct box size and port diameters/length.
Also, other calculations like the resonant frequency of the vehicle you are putting these in and numerous other issues. Seriously, fixya.com is the wrong place to get this answered. Teams spends tens of thousands of dollars and years perfecting their vehicles to compete. Go to a good audio forum and ask this question there. You will receive ALOT better help and you can interact with some very knowledgeable people about your competition wishes. Good luck and have patience!!
What is the sealed and
If you can access the inside of the sub box by removing the speaker, you may be able to measure the 3 dimension of each side of the enclosure. 1 cubic foot is 12x12x12 inches cubed. That is 1728 cubic inches per cubic foot. If you measure the inside dimensions of one of the enclosure sides as 10x14x8 inches, then that is 1120. 1120 divided by 1728 is 0.648 cubic feet. Alternatively, you could estimate the volumes of each side of the box by measure the outside, figuring out where the box divider board is, subtracting the width of the boards used to make and then calculate. Otherwise, I do not know the enclosure that that sub comes in. Good luck. Let us know how it goes.
I need to hook up two audiobahn A1200Q subs to a
The amplifier is only stable to 2 ohms.
Assuming the cubs are dual 4 ohm voicecoils - a 2 ohm load with 2 subs is not possible.
You can only wire up 1 dual 4 ohm voicecoil sub (both positives to amp... and both negatives to amp) to get a 2 ohm mono load.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Can the Audiobahn AEQ8 replace an Audiobahn AEQ6Q. Is it the same foot- print, size and rae connections similar..
Hello William Novelli, if it would be compatible, but you should control the order of the connections, they can vary
I send you the link to download the manuals of both models and compare the connections, if you find it complex, consult a specialized technical service
I hope you find it useful
Regards Franco Dosil
Hola William Novelli, si seria compatible, pero deberas controlar el orden de las conexiones, pueden variar
Te envio el link paravque descargues los manuales de ambos modelos y compares los conexionados, si te resulta complejo, consulta con un servicio tecnico especializado
Espero te resulte util
Saludos Franco Dosil
https://manualmachine.com/audiobahn/aeq7/18414-user-manual/
https://manualmachine.com/audiobahn/aeq8/18268-user-manual/
https://www.manualslib.com/manual/211695/Audiobahn-Aeq6q.html
I have a audiobahn aw1251t 12 inch sub and punch 1000-1db amp how would i wire it up
as your sub is only rated to 400w rms simply connect the sub to either a or b channel outputs you may wish to use an rca splitter before the amp to feed both left and right audio channels into a single channel on the amp. WARNING connecting both channels on the amp to the sub will overload the sub and possibly blow it up so i highly recommend not doing so.
Hi, I have 2 10 Audiobahn aw1000x,4ohm,
dual v.c,600watts each. ...but I can't find information on this model of subs ANYWHERE. I'D love to have a manual, or at least the specs... can anyone help?
i was not able to locate a manual but i did find some interesting information that hopefully may help,
The AudioBahn AW1000X Car Subwoofer Features: dual 4-ohm voice coils, non-pressed pulp cone, huge foam surround, frequency response 23-500 Hz, power range 50-600 watts RMS (300 watts per coil), peak power handling 1,200 watts, sensitivity 91.1 dB, top-mount depth 5-1/4" ,sealed box volume: 0.4-.95 cubic feet, ported box volume: 1.632 cubic feet.
Brand new Audiobahn amp burning smell
i'd need more info but from what you've stated, sorry to break it to you but it sounds likely you've incorrectly wired you speakers and blown your amp. this will prove no doubt an expensive mistake and learning exercise.
I have a 2 ohm
Generally there are 2 parts to this problem
part 1
input signal as these woofers are just subs remember to give them a low line in signal before the amp (see diagram) i like to use rca low pass crossover filters from harrison labs (see link)
part 2
is the wiring configuration of the 2 woofers by wiring them in parallel as shown in the diagram you reduce them to a 2 ohm load for your 2 ohm amp meaning you'll get max loudness and efficiency
Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA Shipping is...
