20 Most Recent M-Audio Fast Track Ultra 8R 8 x 8 USB 2.0 MIDI Interface for Digital Recording Questions & Answers
Take it back and have it repaired under warranty.
Even if you are skilled in electronic repair, the manufacturer has all the service manuals and spare parts you would have to pay for.
And you have already paid for repair under warranty in the price of the unit.
M-Audio Fast... | Answered on Feb 08, 2011
All USB ports have four leads attached. Tthe outside rails contain the positive and negative voltage of 5V and the two inside rails is the transmit and receive. I would take the interface apart and replace the USB connector. Maybe Radio Shack or another electronic shop would have the same USB connector. See:
http://69.84.140.50/content/Article.aspx?Type=L&ID=468
M-Audio Fast... | Answered on Jan 05, 2011
Make sure all other background programs such as anti-virus and anti_spyware, etc are ALL TURNED OFF. At high data rates you don't have processing power to waste servicing these resource hogs. ALSO turn off wireless links.
NEXT: Search for sources of electrical noise. Make sure you use balanaced lines for all audio connections where possible. Make sure ALL and I do mean ALL interconnected equipment is powered from the same receptacle or source. Ground noise can be a problem.
A final thing would be to kill ALL electrical except for the recording system to verify there is not electrical noise being created by a local source in your facility... could be a heater cycling on and off for instance... A thermostat sometimes has contact bounce before it fianlly makes or breaks.
M-Audio Fast... | Answered on Jan 03, 2011
This statement is too much to bare anybody. Please do not disturb us anymore.
M-Audio... | Answered on Feb 27, 2017
Install the Netflix app
  1. From the Start menu, select Store.
  2. Select Search from the upper right corner of the screen.
  3. Type Netflix in the search box and press Enter.
  4. Select Netflix from the results.
  5. Select Install. ...
  6. Return to the Start menu.
  7. Select the Netflix app.
  8. Select Sign in.
http://www.satechhelp.co.za/25121/Netflix-sinotec-smart-tv
visit this site too.
http://electrohelponline.blogspot.com/
Televison &... | Answered 7 hours ago
no, it is an advanced function of the remote. Just buy another one.
Google
make model replacement remote
They are on Amazon, eBay and specialist sellers like www.remotes.com
Televison &... | Answered 23 hours ago
Contact Chanel direct, speak to them and ask why they are not open and report the manager of that branch?
https://www.chanel.com/en_CA/?gclid=CjwKCAjw2Jb7BRBHEiwAXTR4jWZ3Fl33hRbytqx-FYFwWvAUwfRckDUoH2tUk3RiUmFllf8uTsHaChoClx8QAvD_BwE
Televison &... | Answered 3 days ago
First ,what is the current input source? If the source isn't connected to the coaxial antenna (RG59) jack, then most TVs will not have the channel scan option available.
Next, the only L2614XW02 I've found is a version of the Maxent MX-26X3 TV. This TV only has an analog tuner. Very few analog OTA stations are still broadcasting and those that are use low-power transmitters. Thus you have to be close to the signal source to receive the broadcast. For most stations, you'll need an OTA digital to analog tuner converter box. Similarly, if you have cable and use a set-top box, that will not be a signal that the TV will tune in directly. Use the set-top box to search for channels.
I hope this helps.
(Note: the tuner can be damaged by a surge that came through the antenna. My household lost a converter box and a TV following a nearby lightning strike. If this is the case, you may need to replace the TV or at least the main board. ShopJimmy lists that part as out-of-stock, https://www.shopjimmy.com/maxent-dpwb11497-ml-b-main-board-for-mx-26x3-l2614xw02/ )
ask google for the code list
Televison &... | Answered on Sep 18, 2020
nordmende nu323lv lslcd it wont power on and is stuck in standbye any ideas???
Televison &... | Answered on Sep 17, 2020
How to program Dish remote to receiver?
How to Program Your DISH Remote Control
  1. Press the Home button on your DISH remote twice. ...
  2. Select Settings from the on-screen menu.
  3. Select Remote Control from the on-screen menu.
  4. Use the on-screen menu to select the device you want to pair.
  5. Select the Pairing Wizard option from the menu.
More items...
How to Program a DISH Remote ' CableTV.com
Remote Control
www.dish.com > voice-remote > pdf > voice-remote-quick-start-guide
PDF control, indicating it has paired with your. DISH receiver. AUX in. SAT. TV. 4 Press the SAT button on the side of the remote control. 3 Open the front panel of your ...
VIDEOS
https://www.google.com/search?q=Programming+a+Dish+Evolve+Remote+to+the+Receiver.
The applicable code would be found in a compatible remote control.
M-Audio Fast Track Ultra 8R 8 x 8 USB 2.0 MIDI Interface for Digital Recording  Logo
11 questions posted
Top M-Audio Televison & Video Experts
Paul Bade
Geoff
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Televison & Video
Most Popular Question
fast track ultra 8 r ive about 9
  • Televison & Video
