20 Most Recent Kenmore 75012 / 75014 Gas Kitchen Range Questions & Answers
How do I put in my oven door?
The door on k.a. / whirlpool - hinge has a tab that locks rhe hinge and prevents the hinge spring from pulling door closed all the wayslightly lifting and continuing to close thw door lifts it off the hinge rest. Some models have set screws that need to be removed some require door disasembly some ge maytag frigidaire dcs wolf viking etc the door simply lifts off. The hinges stay attached to the app.and some have holes at the pivot of the hinge wherea 1/8 inch metal tabs or nails are inserted and door is ifted up and out....
(That is 1/3 of the job 2/3 is puting it back) lol
3/9/2015 6:25:50 AM • Kenmore 75012 /... • Answered on Mar 09, 2015
Oven makes clicking sounds but
What you are most likely hearing is the relay for the ignitor turning on and off. As far as it not lighting, the ignitor needs to draw at least 3 amps or the safety valve will not allow gas to flow. The Ignitor is going to be under the removable bottom tray and also a heat spreader. The ignitor is a ceramic block with 2 wires coming from one end and a flat carbon 'coil' from the other, an it will attached by a metal bracket.
Your will need a clamp type AC amp meter to check for current. If it pulls less than 3 amps when trying to light, the ignitor is bad and will need replaced. If it pulls more than 3 amps, you most likely have a bad safety valve.
The ignitors run $10-20 usually, but the safety valves can run anywhere from $50 to a couple hundred.
Hope this helps.
9/17/2011 11:45:03 PM • Kenmore 75012 /... • Answered on Sep 17, 2011
When I turn on the oven it doesn't ignite.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
sd544
9/30/2010 1:48:09 AM • Kenmore 75012 /... • Answered on Sep 30, 2010
I can't find my model number on my Sears Kenmore
The tag with the model number is usually located on the rail that is visible with the lower drawer open.
The code you are getting is an indication that the oven got too hot or the control thinks the oven got too hot. It is usually do to one of two parts that have failed.
If the oven did not get too hot and you got the failure code, then the sensor would be bad.
If the oven did get too hot then the ERC (electronic range control) is bad.
5/17/2010 8:39:22 PM • Kenmore 75012 /... • Answered on May 17, 2010
Oven igniter is always needing repair.
Check to make sure that the flame is not hitting the ignitor too hard, too much heat is not good. Also do you have excessive vibration in or around the house? These are sensitive to vibrations that can crack them. Make sure that there is no condensation or wtaer dropping on the ignitor...
And yes they often only lasst a couple of years in great situations...:-(
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
4/6/2010 7:33:50 PM • Kenmore 75012 /... • Answered on Apr 06, 2010
Bottom oven burner will not light
If your Kenmore is like most Whirlpool-built gas ranges, surface ignitors similar to those used in gas dryers are used. These devices have a conductive path fused to a ceramic substrate and are common failures. There are separate units for bake and broil burners.
Check the Sears website under the 'Parts' subsection and enter your range model number. This should bring up a choice of things to do and if you ask for the illustrated parts breakdown, you can see where the ignitor is located, get its part number, and generally order from that same site.
It's mildly disturbing that the range continues to allow gas to flow unignited.
2/7/2009 1:48:58 AM • Kenmore 75012 /... • Answered on Feb 07, 2009
How do I cancel a delayed start when trying to use self clean on Kenmore oven 807189701 Rev B
Unplug the power and cancel it. Never Ever use the self clean feature. We see damage here every couple of weeks. The worst was a burned control board on an oven that all parts were obsolete, so the self clean cost a thousand bucks! Self-cleaning ovens bring the heat so you don't have to spend hours scrubbing. Traditional self-cleaning cycles heat the oven between 800°F and 900°F, helping turn soil and spills to a powdery ash you can then wipe away. They utilize only heat-no chemicals-and are built to withstand high temperatures. (Says Maytag who love selling elements, door locks and other parts),
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ... ‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cle... A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ... ‎How Self-Cleaning Ovens Work · ‎Major Parts Damage
12/3/2023 6:55:11 PM • Kenmore Kitchen... • Answered on Dec 03, 2023
2answers
Kenmore electric range. Model 790.9081. Turned on oven. Loud pop. Tripped breaker. Reset. Cook top working but oven and clock/controls are not. Elements don't look broken.
limited info generic answer will need a multi meter to test circuits -[dont look broken ] is not a solution to your problem
8/20/2023 10:28:01 PM • Kenmore Kitchen... • Answered on Aug 20, 2023
Kenmore Elite 790.99913804 gives an E0 39 error when trying to use the cooktop.
The E0 39 error on a Kenmore Elite 790.99913804 cooktop indicates a communication error between the user interface board and the power supply control board. This error can occur due to a faulty connection or damaged wiring between the two boards. If replacing both the user interface board and power supply control boards did not resolve the issue, it is possible that there is a problem with the wiring harness or another component in the cooktop. It may be necessary to consult a professional technician to diagnose and repair the issue. In addition, it is recommended to check the user manual for troubleshooting steps specific to this model of cooktop. The manual may provide additional information on how to resolve this error code.
6/21/2023 9:10:54 PM • Kenmore Kitchen... • Answered on Jun 21, 2023
Kenmore Elite 790.9505 Range
The Kenmore Elite 790.9505 range is a kitchen appliance designed for cooking and baking. It features a variety of burners, including a powerful 18,000 BTU Turbo Boil burner and a simmer burner for delicate foods. The oven has a large capacity and offers convection cooking for even baking and roasting. The range also includes a number of convenient features, such as a self-cleaning oven, electronic controls, and a built-in timer. Overall, the Kenmore Elite 790.9505 range is a versatile and high-performing appliance that can help make cooking and baking easier and more efficient.
5/6/2023 12:23:59 PM • Kenmore Kitchen... • Answered on May 06, 2023
What's the gas oven ignitor part number for a Kenmore Elite 790.3670?
The gas oven ignitor part number for a Kenmore Elite 790.3670 may vary depending on the specific model and serial number of your appliance. However, a commonly used gas oven ignitor for this model is part number 5303935066. I would recommend checking your owner's manual or contacting Kenmore customer service to confirm the correct part number for your specific appliance. Additionally, it's important to ensure that you purchase a gas oven ignitor that is compatible with your Kenmore Elite model to avoid any potential issues or safety hazards.
3/24/2023 8:52:11 PM • Kenmore Kitchen... • Answered on Mar 24, 2023
Kenmore Elite Duel Oven gas kitchen range. Model 66578003801.No ERROR codes. Lower oven LOCK light flashing.
a hard reset can be most beneficial for assisting in this matter so, have you tried unplugging your appliance for 5 minutes to do a hard reset yet? If unplugging is not easy, turn off the breaker for 5 minutes and do the same thing.
3/16/2023 5:26:08 PM • Kenmore Kitchen... • Answered on Mar 16, 2023
Problem with kenmore elite gas range. Oven will not heat
It sounds like you may have a problem with the gas valve or the igniter in your Kenmore Elite gas range. The gas valve controls the flow of gas to the burner, and the igniter provides the spark to light the gas. If the glow plug is coming on but the gas is not igniting, it could be a problem with the igniter itself or the gas valve. The igniter may not be producing a strong enough spark to light the gas, or the gas valve may be clogged or malfunctioning, preventing the gas from flowing properly. You may want to have a professional technician take a look at your range to diagnose and fix the problem. It is important to have any gas appliance serviced by a qualified technician to ensure safe operation.
2/26/2023 5:35:44 PM • Kenmore Kitchen... • Answered on Feb 26, 2023
Kenmore gas range slow to preheat, takes 1 hour to get to temp.
There are several potential causes for a gas range being slow to preheat. Here are some troubleshooting steps you can try:
  1. Check the igniter: While the igniter may be coming on, it may not be getting hot enough to ignite the gas. Make sure the igniter is clean and free from any debris or corrosion. If it is dirty, gently clean it with a soft cloth. If the igniter is damaged or not getting hot enough, it may need to be replaced.
  2. Check the gas supply: Make sure that the gas supply is turned on and that the gas pressure is sufficient. If the gas pressure is too low, the oven may take longer to preheat.
  3. Check the oven temperature sensor: A faulty temperature sensor can cause the oven to take longer to preheat. Use a multimeter to test the sensor for continuity. If it is not working properly, it may need to be replaced.
  4. Check the oven door seal: A faulty oven door seal can cause heat to escape, making it difficult for the oven to reach the desired temperature. Inspect the seal for any cracks or gaps, and replace it if necessary.
  5. Check the oven igniter safety valve: The igniter safety valve is responsible for regulating the flow of gas to the oven. If it is faulty, it may be restricting the flow of gas, causing the oven to take longer to preheat.
If you are uncomfortable performing any of these troubleshooting steps yourself, it is best to contact a qualified appliance repair technician for assistance.
2/25/2023 1:15:39 PM • Kenmore Kitchen... • Answered on Feb 25, 2023
30" Kenmore gas range door is locked and can not be opened.
If your Kenmore gas range door is locked and cannot be opened, try the following steps:
  1. Check the control panel for any error messages or fault codes. If there are any, try to clear them by unplugging the range for a few minutes and plugging it back in.
  2. Check if the oven is in self-cleaning mode. If it is, the door will automatically lock and will not open until the self-cleaning cycle is complete. Wait for the cycle to finish and the oven to cool down before attempting to open the door.
  3. Try resetting the door latch. Turn off the power to the range for at least 30 seconds, then turn it back on. Press and hold the "Clear/Off" button for three seconds. This should reset the door latch and allow you to open the door.
  4. If none of the above steps work, it's possible that the door latch or locking mechanism is malfunctioning and needs to be replaced. In this case, it's best to contact a qualified technician to diagnose and repair the issue.
2/24/2023 9:34:43 AM • Kenmore Kitchen... • Answered on Feb 24, 2023
How many watts are needed to operate a Sears Kenmore gas range model #790.78669602 serial #VF71315812. Need to calculate solar energy needed.
The Sears Kenmore gas range model #790.78669602 does not require electricity to operate. It runs on natural gas or propane and is ignited by a pilot light or an electric igniter powered by a battery. Therefore, no watts are needed to operate the range and it does not require solar energy.
2/23/2023 2:10:21 PM • Kenmore Kitchen... • Answered on Feb 23, 2023
Kenmore 75012 / 75014 Gas Kitchen Range Logo
Popular Tags
13 questions posted
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Kitchen Ranges
Most Popular Question
oven makes clicking sounds but
  • Kitchen Ranges
