20 Most Recent Apple M9248LLA iMac G5 1.6GHz Desktop Computer Mac Desktop Questions & Answers
A question mark on the boot screen is an indication that the machine can't find your boot drive. Usually this is trivially fixed by resetting the PRAM (holding down command-option-P-R after turning on the machine with the power button, until you hear the chime three times).
However, taken in conjunction with your other symptom, I would suspect a failing drive or a failing SATA channel (less probable). Does it boot from the original DVD without these symptoms? After booting from the DVD, are there any indications from the tools that the hard drive may not be showing as present, or may show intermittently?
If you have a good backup (Time Machine or otherwise), I would erase and reformat the disk with "write zeroes to all records one time," then reload the backup, and see if that fixes the problem. If not, you will need to replace the drive, and reload the backup (hope you have one) onto the new drive.
Apple M9248LLA... | Answered on Nov 01, 2010
Can your system had an licenced antivirus software. If no get it. This file can a virus. Thank you.
Apple M9248LLA... | Answered on Jun 08, 2010
1. in imac u first pull out the display
2. then remove the motherboard in the backside of the motherboard u see cmos battery remove the battery , replace new one
Apple iMac... | Answered on Sep 04, 2019
You do not need to setup AirDrop as such. Just turn on the wifi and on the Finder sidebar go to AirDrop.
Apple iMac... | Answered on Aug 23, 2019
If you are sent bulk mail then you are not used public email server. Because public email sent normal 10-50 max email one day. If you are bulk mail sent then you are purchase extra space or server. If you are want yahoo through sent email then contact yahoo and ask i want to sent bulk mail so yahoo available space or service and also yahoo charge taken.
Thanks,
MacHealthCheck
Apple iMac... | Answered on Jan 25, 2019
Please select a different keyboard layout
Click the Apple icon from your menu bar, select System Preferences, and then follow these steps.
1) Click Keyboard.
2) Make sure you're on the Input Sources tab.
3) Click the plus sign button on the bottom left.
In the pop-up window, you'll see a list of languages on the left and options for them on the right. You'll also see a preview of the keyboard layout.Select the language you want and then pick the option on the right. For example, French > ABC - AZERTY or English > Dvorak.
5) Click Add.
Apple iMac... | Answered on Jan 17, 2019
For removing the guest account
Click on Apple menu on the desktop and select system preferences then click the user & Users icon in the system action.
Click the bottom right corner and then enter you account and password as prompted.
This unlock the setting allow to make a changes.
Apple iMac... | Answered on Jan 02, 2019
Send it as an email to yourself
Apple iMac... | Answered on Dec 18, 2018
If your Imac is in Warranty period than don't go for these process. Call your near by Apple support any demand for service http://www.apple.com/imac/ . but if you are out of warranty than
Try to Eject it from Desktop Disk Drive or Restart your Imac and try to eject. if still not help than follow Mac Support .
Apple iMac... | Answered on Nov 26, 2018
hi,
posible theres a problem on ODD lense, you try to clean the lense or replace new odd
thank you
Apple iMac... | Answered on Oct 04, 2018
Hi
Attachments to email should be less than 10mb.
Your ISP sets the limit.
Open an email and get it ready to go.
Put cursor where you want the attachment to sit on the page.
Drag your file to be attached, from the Desktop to the Email window & drop. Then clik send.
For larger attachments:
Use the free DropBox to share files with friends. You place files to be shared in the Dropbox Folder which shows in the top menu of a Mac. Very simple to use, once set up. https://db.tt/7ByRbUj
Cheers
Trevor
Apple iMac... | Answered on Sep 20, 2018
To know how to repair powerpoint file - this is Google. But in it there is PowerPoint online service it works under Windows, Android, Mac with any types of files. Just try it on How to recover data from damaged PowerPoint presentation
Apple iMac... | Answered on Jun 07, 2018
I would offer you some variants, what to choose - this is your preference...
As we know Google is our friend - how to repair damaged pdf file - this query might be too
Nowadays day-by-day Macintosh Online Service becomes more popular, it was found https://onlinefile.repair/en/pdf.html on search machine
Apple iMac... | Answered on Mar 30, 2018
command and f5 should turn it off. or go into preferences and accessibility to turn it off
Apple iMac... | Answered on Jan 23, 2018
Some mac user solve this problem by
1. Boot up from your OS X Install Disk / USB Stick and Launch Terminal and type "diskutil partitionDisk disk0 jhfs+ MacintoshHD R".
if need any technical guidance over follow http://store.apple.com/us/help/contact and
Apple and Mac Technical Support on Mac OS X .
Apple iMac... | Answered on Dec 29, 2017
Really to descriptive so take a look at this tutorial http://support.apple.com/kb/HT4848 . If still not able to solve or you had not any technical knowledge follow Apple and Mac Technical Support for OS X .
Apple iMac... | Answered on Dec 07, 2017
The Mac OS Scroll Bars default behavior changed some time ago so that they are now NOT VISIBLE in most apps unless you begin scrolling.
However, you can change this behavior. Go to the Apple Menu in the upper-left corner, select "System Preferences," click on "General" and change "Show Scroll Bars:" to "Always."
Regards,
Ellsworth
Apple iMac... | Answered on Apr 15, 2017
Apple M9248LLA iMac G5 1.6GHz Desktop Computer  Mac Desktop Logo
2 questions posted
Popular Products
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iMac Apple
  • iMac Apple
Most Popular Question
whats wrong apple computer blank
  • Computers & Internet
