20 Most Recent 2010 Land Rover / Range Rover LR4 / Discovery 4 FloorLiners Questions & Answers
Check alternator output with a volt tester ,check drive belt is on and not slipping.
2010 Land Rover... | Answered on Feb 18, 2016
Will any metal detector manual serve, or do you have a specific make and model in mind?
Vehicle Parts &... | Answered on Sep 15, 2020
I had a problem similar to that which you described the car would start fine then few seconds later it would cut out completely.
i changed the fuel pump, Fuel pump relay and still the problem was there and a a code of P0230 i cleaned the ECU connections which still didnt change anything so i put a jumper wire to bypass the fuel pump relay it got it to work fine.
With abit more digging and head scratching i opened up the ECU and found one wire broken.
I soldered it back in place and behold the car worked a dream no problem ever since.
I also removed the bypass which i put on the fuel pump relay and put the relay back.
Dont know if this would fix your problem but hopefully it would be of help.
Vehicle Parts &... | Answered on Jul 10, 2020
Yes, you should go for car wrap, it has many advantages like a high quality film will help you to prevent color fading, flying glass splinters during accidents and heat protection etc.
A nice Auto folie will enhance the appearance of your vehicle.
Vehicle Parts &... | Answered on Jun 09, 2020
you can purchase from:
https://www.amazon.com/Adapter-Charger
Vehicle Parts &... | Answered on May 29, 2020
https://help.compustar.com/s/article/How-Do-I-Exit-and-or-Enter-Valet-Mode
You can see this link.
Vehicle Parts &... | Answered on May 07, 2020
Suggest to do a patent search and review some diagrams. That will get you started.
Vehicle Parts &... | Answered on Feb 13, 2020
Google
year make model valet button
it is impossible for us to guess!
Vehicle Parts &... | Answered on Jan 12, 2020
on a car security, no idea, but on Android, this is how.
How to reset your Android screen lock security pattern ... TechRepublic Draw the pattern, click Continue, draw the pattern again, and you're back in business. You can also increase the security of your phone by setting it to lock ...
How to reset your Android screen lock security pattern TechRepublic
Vehicle Parts &... | Answered on Jan 06, 2020
When I hold the valet switch like am ask the led light lights up and stays on no chirping at all but if I hold the valet switch when the car is in the on position I get a chirp help someone please
Vehicle Parts &... | Answered on Dec 28, 2019
The supposed science behind polygraph tests is flawed, even proponents say it's only 90% accurate, (critics say it's far less at 70% or lower) so, at a minimum, for every 10 people that are tested 1 of them either gets accused of something they didn't do, or gets away with doing something. (or 3 out of 10 if you take a critic's side) And when it's done by Police, they are legally allowed to lie to you about your results!
Vehicle Parts &... | Answered on Dec 11, 2019
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Vehicle Parts &... | Answered on Nov 30, 2019
same as jupiter all good
Vehicle Parts &... | Answered on Nov 08, 2019
Don't click on spammer Victoria Archer, as FIXYA doesn't remove most spammers automatically. Volunteers answer questions without charge.
https://www.scorpionauto.com/car-remote-alarm-immobiliser-scorpion-sa30/
Contact information.
https://www.scorpionauto.com/contact/
Vehicle Parts &... | Answered on Oct 25, 2019
Tip
Longer lasting engine maintenance
Your engine will last a lot longer as far as the main engine components if you 1)change your engine oil at vehicle recommended mfg intervals.TIP: if you live in hot climates you should change your oil more often and at less miles .2500 to 3000 ml. every 3 months because the climate the hot temperatures break down oil viscosity at a higher rate thus needed more frequent oil changes for the best engine engine lasting performance.2) always use the recommended weight example (5/30w)TIP: Also for best results the recommended rating of the oil for example on the back of the oil bottle is a rating 2 or 3 letters in a circle .Older vehicles use a different rating than newer vehicles and some times they are not interchangeable this information should be available at your local parts store.3)TIP;: Always use the recommended (brand) oil filter.With the way cars are now especially ones with overhead cams and chains ,aftermarket filters might not supply the same pressure aspects of the original oil filter, So as far to have less or more pressure than that is needed to maintain these components correctly with the correct pressure.
Thanks hope this helps
on Oct 22, 2019 | Vehicle Parts & Accessories
check compression
Vehicle Parts &... | Answered on Oct 14, 2019
2010 Land Rover / Range Rover LR4 / Discovery 4 FloorLiners Logo
1 questions posted
Top WeatherTech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a WeatherTech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • WeatherTech Vehicle Parts & Accessories
Most Popular Question
meaning charging system fault
  • Vehicle Parts & Accessories
