20 Most Recent Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Questions & Answers
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Kenmore 96212 /... | Answered on Oct 01, 2010
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
unplug the range.
wait 1 minute.
wait 2 minutes.
Kenmore 96212 /... | Answered on Sep 25, 2010
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Kenmore 96212 /... | Answered on Sep 07, 2010
It is usually always an infinite switch, Rarely is it a surface element. The fact that the power light does not go on is also a good clue that your switch is bad. If it was a problem with the wiring to the element, your light would be on. When you order the switch, ask for the exact origional replacement. They have some generic switches that have shafts that have to be broken off to the right size for your range. These are not as reliable as the origional which usually has a much stronger shaft. Good Luck, Appliance Specialists.
Kenmore 96212 /... | Answered on Jan 26, 2010
try holding the door switch closed and press cancel. that usualy takes care of it. if that doesnt work send your model number out and this will help.
Kenmore 96212 /... | Answered on Feb 16, 2009
What your going to have to do is replace the infinate control for that burner. ( thats the control you turn to sw it from high to low heat )
good luck
Kenmore 96212 /... | Answered on Jan 10, 2009
It will be alright just dont put it on top of the burner
Kenmore 96212 /... | Answered on Dec 24, 2008
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Kenmore 96212 /... | Answered on Dec 09, 2008
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Kenmore 96212 /... | Answered on Dec 08, 2008
those codes indicate a bad oven sensor or the wiring to it
Kenmore 96212 /... | Answered on Mar 25, 2008
to exit sab mode press and hold the "cook time" and "delay start " pads for 3-5 secs. the letters "sab" will appear in display and your good to go!
Kenmore 96212 /... | Answered on Mar 07, 2008
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
Popular Tags
35 questions posted
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Kitchen Ranges
Most Popular Question
while using kenmore 790 9621 smooth
  • Kitchen Ranges
