20 Most Recent Kenmore 99123 Electric Kitchen Range Questions & Answers
Robert,
What did you mean by calibration went to zero says it is good?
Obviously you want to secure power from the runaway broiler element. -as mentioned - pop the breaker.
Power must be getting to the broiler element either from a bad switch or the control board has malfunctioned.
Rather than submitting new questions, which can be confusing - add comments to the original questons. This helps keep all the info together.
Kenmore 99123... | Answered on Jan 08, 2015
Its common for replacement switches to be different then the original because the original has gone obsolete. Usually the replacement comes with a wire diagram. Given the numbers you have provided I don't think that switch you have is compatible but I wouldn't know unless I seen it.
Kenmore 99123... | Answered on May 19, 2014
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore 99123... | Answered on Sep 05, 2013
Sometimes food gets on a element. This causes a hotspot. The element makes a pop and goes bye bye. Remember this. When checking or replacing oven elements the L-2 power line goes directly into the element and is hot all the time the oven is plugged in. Be sure the power is not connected before attempting any repairs.
A simple check like this will help determine the problema:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore 99123... | Answered on Nov 04, 2012
it means that your oven is showing a restart code
Kenmore 99123... | Answered on Nov 01, 2012
I would replace the elements with new ones
Kenmore 99123... | Answered on Oct 24, 2011
yes that speeds up the preheat prossec
Kenmore 99123... | Answered on Sep 04, 2011
Kenmore 99123 Electric Kitchen Range Logo
Popular Tags
64 questions posted
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Kitchen Ranges
Most Popular Question
switch much get
  • Kitchen Ranges
