20 Most Recent
Singer 9960 Quantum Stylist Sewing Machine Questions & Answers
How to baste?
Basting is simply using a long stitch that can be pulled out after you put the main stitch in. It holds fabric in the right place till it is sewn.
Singer 416
Probably not. Those will have to be replace by a machine technician.
Why does the needle always stop down in the fabric?
I just took a look at your user's manual (I recommend you go to the Singer site and download it--it's free), and on page 20, it says that the top button of the set of three buttons above the needle shaft is the needle up/down button. If you press it when the machine is NOT sewing, it will reset it to stopping with the needle UP instead of DOWN. In other words, it resets the needle's default position, but you must do that when it isn't sewing anything.
New 9960 Singer sewing machine keeps jamming
try a new needle-- one for the fabric your sewing
make sure the top thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
if the suggestions don't help
take the machine back and tell them what it's doing and ask for another one
New 9960 sewing machine keeps jamming
try a new needle--the correct one for the fabric and thread
make sure the top thread has not come off the thread take up lever
rethread the machine top and bobbin-- using every thread guide
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help, then taking the machine to be checked would be a good idea.
Makes one stitch then abrupt stop with threads bunching up from bottom
Have you taken the bobbin out and made sure there is nothing caught in the bobbin race area. Maybe even unscrew the plate and take the whole bobbin race assembly apart and clean well. Once that is done put back together then re thread machine. Next I would start by hand turning the machine and doing some stitches slowly with the fly wheel make sure to to forwards only never turn the fly wheel back wards. If everything seems clear give it some power slowly and see how it goes.
