20 Most Recent Giorgio Armani Emporio Armani AR0584 AA Watch Questions & Answers
acabo de adquirir un reloj armani AR0431 segui las instrucciones ajuste fecha y hora, pero no trabaja..que pasa a caso no bienen de fabrica con la bateria instalada? o cual podria ser el problema?
Giorgio Armani... | Answered on Dec 04, 2012
This may be due to a poor battery connection, a low battery, a dry movement, or debris in the movement. I strongly recommend taking it to a local Certified Master Horologist for assessment and repair. Estimates are usually free.
Giorgio Armani... | Answered on Feb 23, 2011
If the humidity has been condensing or happening for a period of tmie longer than 3-4 hours, this watch should be taken to a Certified Master Horologist in your local area as soon as possible. The timepiece should be opened, dried out, resealed, and water tested.
If humidity comes and goes away within 3-4 hours it is a normal occurrence from extreme temperature change (A/C to outdoor heat, vice versa) (Outdoor cold to indoor heat, vice versa).
I have just posted added a manual for this watch that will be available looking at my profile. It should be added within 24 hours of this time and date.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.
If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
Giorgio Armani... | Answered on Dec 05, 2014
Giorgio Armani Emporio Armani AR0584 AA Watch Logo
Popular Tags
4 questions posted
Top Giorgio Armani Watches Experts
Janelle Schoonover
Janelle Schoonover
JonSnell Electronic
JonSnell Electronic
Are you a Giorgio Armani Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Giorgio Armani Watches
Most Popular Question
seems humidity
  • Watches
