20 Most Recent Staples SPL-250 10-Digit Display Calculator Questions & Answers
Dont know what you are saying.
Basically turn it off and on if your stuck.
Staples SPL-250... | Answered on Jan 05, 2016
That is because when you turn it off the cooling fan stops and if you have been using it a lot, the heat immediately builds up and it trips the overheat switch.
If should restart after about an hour. Unless it is an industrial shredder, you should use it no longer that 5 minutes. Shred a little and often.
Staples Office... | Answered on Apr 28, 2020
IF YOU LOOK INTO THE SLOT WHERE YOU FEED THE PAPER...GET A FLASHLIGHT ........IN THE MIDDLE OF THE SLOT YOU WILL SEE A TINY SWITCH. THAT THING SOMETIMES GETS GUMMED UP WITH GLUE FROM ENVELOPES AND SUCH... TRY SOME WD-40 ON THAT SWITCH... WITH THE MACHINE UNPLUGGED PUT PAPER IN THE SLOT TO MOVE THE SWITCH SO THE WD-40 CAN LOOSEN UP ANYTHING .... THEN TRY BLOWING AIR IN IT....
ARE YOU SURE THAT THE TOP OF THE SHREDDER IS SITTING FLUSH WITH THE PORTION IT RESTS ON??? THAT COULD ALSO MAKE IT NOT WORK..... OR IF THE BASKET NEEDS EMPTYING THE TOP WONT REST FLUSH ON THE BASKET.
Staples Office... | Answered on Feb 18, 2020
ask google or your local home improvement store
Staples Office... | Answered on Nov 23, 2019
Usual cause is paper jammed in the cutting heads.
Staples Office... | Answered on Sep 17, 2019
it has out lived you , replace it no parts made to repalir it
Staples Office... | Answered on Jun 16, 2019
Staples SPL-250 10-Digit Display Calculator Logo
11 questions posted
Top Staples Office Equipment & Supplies Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Staples Office Equipment & Supplies
Most Popular Question
reset just basic adding
  • Office Equipment & Supplies
