20 Most Recent Geneve 14K Solid Gold Mini OW199 Watch for Women Questions & Answers
In some watches it is necessary to turn the crown wheel (usually anticlockwise) before pulling it out. (This is to give added water resistance).
Try turning it left before pulling.
Geneve 14K Solid... | Answered on Jan 06, 2012
sorry but we know of no way to find backs for watches here
Geneve Watches | Answered on Jan 11, 2018
Ask at a jeweller.
Geneve Watches | Answered on Aug 21, 2017
you should just contact the company directly
Geneva Watch Group
1407 Broadway
Suite 400
New York, NY 10018
Phone: 1-888-GWG-TIME begin_of_the_skype_highlighting 1-888-GWG-TIME
end_of_the_skype_highlighting
(888-494-8463 begin_of_the_skype_highlighting 888-494-8463 end_of_the_skype_highlighting)
Fax: 212-221-9414
or go to this link
http://www.genevawatchgroup.com/contact_form.shtml
They are the company that makes the watches. They can help you give you some address you might be able to mail or take your watch 2. good luck and best wishes.
Geneve Watches | Answered on Sep 22, 2010
Found an email address in Switzerland for Bulova. Contacted them and they've given me the name & address of a Bulova dealer here in town.
Geneve Watches | Answered on Oct 08, 2009
Take it to any watch maker shop who does customize crystal
and if you are in chicago we do customize crystal
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Geneve Watches | Answered on Sep 24, 2009
Hi Tarynlarson,
Ok this can be done by GENTLY pulling out the crown till you hear or feel 2 clicks. Sometimes the crown has to unwound first, as you have not mentioned a specific model I am trying to be through.
Then you canjust rotate the crown and the hands should move and you can get it to the desired time.
When you have finished simply rescrew the crown back down.
Hope this helps?
Geneve Watches | Answered on Jul 15, 2009
Such a fast gaining usually is caused by dirty or magnetized hairspring, resulting in uneven coil amplitude (some of the coil rows are sticking together or touching each other). This causes the watch to run unbelievably fast.
To get the watch properly fixed you need to give to the watchmaker.
Alternetively; you can fix it yourself, but it will not last long.
For this you will need:
Case opener,
Dust blower (resin ball with nozzle),
Lighter fluid (ZIPPO),
Dropper (like one in eyedrops package).
Do as follows:
Open watch caseback,
Check for the fastest moving part in watch movement and you will see the hairspring fitted on it (pulsing outwards and inwards very fast).
Fill the VERY CLEAN dropper with lighter fluid.
Put ONE drop of lighter fluid on hairspring (DO NOT TOUCH IT),
Wait for a 10 seconds,
Dry out the lighter fluid with dust blower by vigorously squeezing it and pointing the nozzle on to hairspring from approx. 2-3 inches away.
Lay the watch on the table (dial down) and cover it with a clean, dustless cup. Leave for 15 minutes.
Fit the caseback on and enjoy your watch again.
Do not forget to rate, please.
Geneve Watches | Answered on Jan 27, 2009
Your watch needs to be clean,so that the old oil will be taken out,and change it with a new fresh oil.Old oil can caused the machine to stop,because old oil become sticky causing machine small gear stuck up and gear shafting can't move .
Hope it may help you;
Regards;
VOTIT
Geneve Watches | Answered on Oct 07, 2008
Need more detail. Model number. This should go from 4.5K to 6K EUR
Watches | Answered on Jul 20, 2020
Request time-setting instructions from Oshen.
Watches | Answered on Jul 15, 2020
Tip
Finding replacement battery for watch (DIY).
If anyone opted out to replace battery in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help.
on Jul 09, 2020 | Watches
pull stem out a bit and rotate it to the proper time
Watches | Answered on Jul 07, 2020
The big one under the 12 (minutes) hand?
That only moves in Chrono mode. If it is the little dial, take it to a jeweler who does watch repairs
Watches | Answered on Jul 03, 2020
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
Watches | Answered on Jun 28, 2020
Geneve 14K Solid Gold Mini OW199 Watch for Women Logo
Popular Tags
1 questions posted
Top Geneve Watches Experts
Janelle Schoonover
Janelle Schoonover
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a Geneve Watch Expert? Answer questions, earn points and help others
View Most Popular
Geneve Watches
  • Geneve Watches
Most Popular Question
stem want pull out set time
  • Watches
