20 Most Recent ULINE U-Line 2000 Series U-CLR2160S-01 Questions & Answers
I just had the same trouble after connecting it to my new filtration system. Yes, if you pour water in with a funnel, it will make ice. You need to be wary of overflowing, as it will drip into the ice reservoir, so close the door quickly so overflow will come out the ice dispenser.
ULINE U-Line... | Answered on Oct 22, 2015
Try Googling (avid)(2078km)(manual) without parens.
Hardware &... | Answered 2 days ago
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Hardware &... | Answered on Jul 25, 2020
It's important to make sure everything is okay with your boiler. That means that it turns on and works just fine when you want it to, and in the same way it should also turn off when it needs to be turned off.
Boilers not turning off might not be a problem in your home but there certainly are some homeowners who struggle with this issue. This issue needs to be fixed right away because boilers that won't turn off could increase the risk of overheating in your home. Not only that, but you'll also find yourself paying more since your boiler won't stop running.
You can check your boiler's thermostat and see if anything changes when you try to turn the temperature levels down. If nothing happens, you should contact an expert to check the thermostat. Hiring an expert offers many advantages. Your heating system professional will also look for other areas that could be causing the issue such as the valves, the programmer, and the intricate wiring inside the boiler. These areas require the skill of an expert that's why it's best to visit the website of I-Delta to get connected with a professional who will help you.
Hardware &... | Answered on Jul 11, 2020
I was just cleaning out a drawer and came across the instructions (two months after I worked through the setup!!). If you would like I can create two .jpg images and send them along. The original printing is pretty small. [email protected]
Jack
Hardware &... | Answered on Jul 06, 2020
Owner's manual troubleshooting? Otherwise my wild guess: Change the arms without power, tighten and retry plugin.
Hardware &... | Answered on Jun 29, 2020
1) Copy following link to help identify Stanley (Westinghouse) timer, and download possible instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Add comment and describe timer in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Hardware &... | Answered on Jun 27, 2020
See the links and videos, it's either jammed or low water flow.
https://www.google.com/search?q=Why+won%27t+melnor+sprinkler+ocillate
Hardware &... | Answered on Jun 22, 2020
try it and see
normally such items loose settings once the power is removed
Hardware &... | Answered on May 05, 2020
By magic on your mystery item :>D
Timers don't go in feet, they go in minutes!
Google
make model manual
Hardware &... | Answered on Apr 26, 2020
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Source: http://www.kgwanyape.com/solutions/isg1201-geyser-load-control-timer/
Hardware &... | Answered on Apr 18, 2020
http://pdf.lowes.com/installationguides/720413934302_install.pdf
Hardware &... | Answered on Apr 17, 2020
ULINE U-Line 2000 Series U-CLR2160S-01 Logo
1 questions posted
Top ULINE Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an ULINE Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • ULINE Hardware & Accessories
Most Popular Question
water not pumping up reservoir manually
  • Hardware & Accessories
