20 Most Recent Brother XR-65t Mechanical Sewing Machine Questions & Answers
Does light come on. Still could be bad cord replace.
Brother XR-65t... | Answered on Nov 15, 2017
You need to tighten the tension on the bobbin thread as it is too loose and is being pulled through by the tension on the top which is probably correct. First check that the bobbin is in correct. I know it's frustrating but even after 40 yr it's where I start if it's all in right then tighten the screw on the bobbin case a little at a time till you get it to the right tension. The thread coming out of the bobbin case should take a pull for thread to come out if you hold the thread and turn loose of the bobbin case and the thread unwinds like a yo-yo it's to loose. The bobbin should stay in the case wile you test it this way.
Brother XR-65t... | Answered on Apr 21, 2017
put it on the table and click the button behind it should get back on
Brother XR-65t... | Answered on Jul 26, 2016
it's possible that the panel light with out and needs to be replaced or there could be something wrong with the computer
Brother XR-65t... | Answered on Jun 18, 2015
Thread the machine with the presser foot up and see if this will remedy the problem.
If not, refer to the manual to be sure the threading and bobbin are set up as they should be.
If the bobbin thread and top thread continue to not link together, it could be the timing needs to be adjusted.
In this case, take the machine to a Brother dealer for service along with a sample of the stitching.
Brother XR-65t... | Answered on Sep 25, 2014
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
16x63 needle system, unless it's been retimed for something else. Suggest you might want to find the dull, bent up or otherwise still intact needle and show it to your industrial supplier or repair person, so they can check for you.
Needle system tells you about the length and timing distance of the needle: see, e.g.: http://designer-entrepreneurs.com/blog/illustrations/Singer_Needle.pdf Size tells you about the diameter of the needle: here's a suite of home sewing machine needles, all of the same needle system, but one of the photos shows a comparison of sizes:
http://www.picturetrail.com/sfx/album/view/17206792
Brother XR-65t... | Answered on May 25, 2014
could be the on/off switch has gone out, could be the motor, or a part is broken, if it's electronic, the computer could have gone out
it would have to be checked to see what happened
Brother XR-65t... | Answered on May 06, 2014
Likely broken threads wrapped around internal components. Have it prefessoinally serviced.
Brother XR-65t... | Answered on Jan 10, 2014
Brother XR-65t Mechanical Sewing Machine Logo
126 questions posted
Top Brother Sewing Machines Experts
Irene Tulloch
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
while in middle sewing kind jammed up
  • Sewing Machines
