20 Most Recent Euro-Pro Dressmaker 998B Questions & Answers
Manual Empisal Dressmaker mk3 / model 620
try manualsonline.com or ebay.
11/3/2017 5:52:51 AM • Euro-Pro... • Answered on Nov 03, 2017
For the dressmaker II, the first bobbin, I got through step 1-5 but where the does step 6 go BECUZ that's really trippin me, PLS tell me. And the instruction is not clear at all, I don't understand it
Hi Vicky, I hope this helps you: 1. Remove the slide cover plate by sliding it toward you, and lift up the bobbin and the bobbin case from the machine. 2. Put the bobbin pin into the hole on top of the hand wheel and place an empty bobbin on the bobbin pin (spindle). 3. Lift the large spool pin from the back of the machine and place the spool of thread on the large spool pin. 4. Place the bobbin winder tension clip into the hole in the back of the machine. 5. Pull the thread to the left and pass it through the bobbin winder tension disc. 6. Insert the thread through the hole in the bobbin from the inside out and leave about 3" of thread out. (ensure that the hole on the bobbin is facing upwards) 7. Hold the end of the thread and start the machine, either by pressing on the start button or the foot control. After the bobbin winds a few turns, stop the machine and cut the thread close to the bobbin. (Cut the thread end that is protruding from the hole at the top of the bobbin). 8. Start the machine again and continue winding until the bobbin is full or the quantity of thread is enough for your needs. 9. Stop the machine and cut the thread. Remove the bobbin from the bobbin pin. 10.Take out the bobbin pin from the hand wheel and push back the large spool pin into the slot in the back of the machine. Good luck :)
7/6/2015 11:40:05 PM • Euro-Pro... • Answered on Jul 06, 2015
2answers
Can i fina a find manuel for a dressmaker singer sewing machine made in the 1950-1960s
Euro Pro Dressmaker 998B Owner Manual also customer service is:
888-633-8635
Average Wait: 31 mins - Monday through Friday, 8:00 a.m. to 4:00 p.m. C.T. the online manual is below: http://www.manualslib.com/manual/451796/Euro-Pro-Dressmaker-998b.html hope that helps if not let me or someone here know and will do our best to help you.
12/15/2014 4:36:23 PM • Euro-Pro... • Answered on Dec 15, 2014
Bobbin will not pick up needle
when you insert the bobbin into the bobbin case and insert into machine, make sure there is a long tail coming out of the bobbin. Thread machine correctly and when trying to "pick-up" the bobbin thread, make sure you are spinning the flywheel the right direction.
7/21/2014 5:12:04 AM • Euro-Pro... • Answered on Jul 21, 2014
0answers
Dressmaker 998B
Be the first to answer 5/6/2014 5:45:04 AM • Euro-Pro... • Posted on May 06, 2014Be the first to answer
0answers
Tension
Be the first to answer 4/21/2014 3:25:19 AM • Euro-Pro... • Posted on Apr 21, 2014Be the first to answer
0answers
0answers
Shark 998a sewing
Be the first to answer 1/28/2014 3:31:41 AM • Euro-Pro... • Posted on Jan 28, 2014Be the first to answer
Victoria sewing machine fy700
just buy a new bobin
6/26/2013 5:07:52 PM • Euro-Pro... • Answered on Jun 26, 2013
2answers
I have a Euro-Pro Dressmaker 998B and have lost the bobbin case. where can I buy one or any parts for that matter?
trysewingpartsonline.comsew4less.comsewingmachinesplus.com
4/26/2013 3:36:18 PM • Euro-Pro... • Answered on Apr 26, 2013
Euro-Pro Dressmaker 998B Logo
86 questions posted
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Euro-Pro Sewing Machines
Most Popular Question
euro pro dressmaker 998b lost bobbin
  • Sewing Machines
