20 Most Recent Janome MyLock 204D Serger NEW MyLock 204D Serger Questions & Answers
HI, this sometimes happens when it needs cleaning. Sometimes lint and thread gets caught underneath the sewing plate, so try giving it a thorough clean. Hope it helps.
Janome MyLock... | Answered on Aug 24, 2019
Try searching the internet for:
Make + Model + the word "Manual"
or contact manufacturer support or a dealer.
Janome MyLock... | Answered on Sep 12, 2016
Hi Selma, The links below are a FREE 42 page Instruction book and a youtube video showing a janome overlocking tutorial, Also there's videos down the right side of that link that may help as well........... CHEERE..
http://janome.com/siteassets/support/manuals/sergers/inst-book-7034d-english.pdf
Janome Domestic Overlocking Machine Tutorial
Janome MyLock... | Answered on May 11, 2016
the thread is most likely binding somewhere in the path. Pull out thread, use canned air or compressor to blow out path and rethread.
Janome MyLock... | Answered on Aug 15, 2014
Check page 62 of your User Manual (En, Sp, Fr version)
Look here for a Janome User Manual :
Janome New Home MyLock ML 204 Overlocker Serger Sewing Machine Users...
Look here for a Janome Workshop Service Manual :
Janome Workshop Service and Repair Manuals Buy Download Janome New Home...
Janome MyLock... | Answered on Jun 21, 2014
Unthread that needle and rethread making certain it is following the thread path exactly AND that the thread has actually gone between the tension discs. Check for any bits of thread / fluff lodged in between the tension disc. Are all the threads good quality and the same brand / type?
Good luck
Janome MyLock... | Answered on Oct 21, 2013
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Janome MyLock... | Answered on May 31, 2013
Sound like the bobbin thread is not 'locking; with the top thread. Check thread tension settings. Is it OK with other embroidery?
Also check the corre`t needle is fitted and that it is a fresh one!
Janome Crafts &... | Answered on Oct 21, 2013
Try several applications with paper towels and a WARM iron. The heat will cause the wax to soak into the paper towel.
Crafts & Hobbies | Answered on May 05, 2020
https://help.cricut.com/hc/en-us/articles/360009429174-My-mat-will-not-load-into-my-machine-at-all
Crafts & Hobbies | Answered on Apr 21, 2020
You can perform a Hard Reset on the Cricut Expression 2 by following the steps below: Power off the Expression 2 machine. Hold down the magnifying glass, pause, and power buttons all at the same time.
https://fasrand997.weebly.com/how-do-i-reset-my-cricut-explore-air-2.html
Ensure that a cartridge is loaded in the machine, as the Load Mat button may not function if a cartridge is not loaded. ... The Cricut may think that the mat is already loaded in the machine. If this does not help, proceed to 4. Press the Reset All button to clear all commands and then press the Load Mat button again.
Crafts & Hobbies | Answered on Apr 19, 2020
SEARCH WWW.YOUTUBE.COM
Crafts & Hobbies | Answered on Apr 13, 2020
chec h with lionel online search or a model railroad club/forum
Crafts & Hobbies | Answered on Apr 04, 2020
google
Crafts & Hobbies | Answered on Apr 01, 2020
jag vet inte du f?r fr?ga n?gon annan
Crafts & Hobbies | Answered on Feb 04, 2020
Hello, Donna -
The number 42733 is connected with the Bucilla cross stitch kit for the "Mad Bluebird".
Therefore, you need to contact the Bucilla company regarding the incorrect pattern.
The parent company for Bucilla is Plaid Enterprises. This is the link to the Plaid Enterprises Contact Us page:
https://plaidonline.com/about/contact
Note: Fixya.com has no affiliation with Bucilla, Plaid Enterprises, or any other handicrafts business.
Best wishes.
Crafts & Hobbies | Answered on Dec 27, 2019
Janome MyLock 204D Serger NEW MyLock 204D Serger Logo
11 questions posted
Top Janome Crafts & Hobbies Experts
Ruth summersides
ray gallant
Carolyn Rogers
Are you a Janome Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Crafts & Hobbies
Most Popular Question
loose stitch right needle thread serger
  • Crafts & Hobbies
