20 Most Recent Janome 4052LX Mechanical Sewing Machine Questions & Answers
Janome sewing machine can't get it to sew the thread isn't pulling the bobbin thread through
Install a brand new needle. If it still does not pull up the bobbin thread, then the machine is probably out of time. Search for sewing machine timing or take it for service.
4/4/2017 2:25:42 AM • Janome 4052LX... • Answered on Apr 04, 2017
Why does the thread from cloging needle after several stiches?
I would think it is not chatching the bobbin thread or the tension is to lose.
7/24/2014 6:04:53 PM • Janome 4052LX... • Answered on Jul 24, 2014
4052 How do I take the plastic case off to service
Be careful if you have a two piece body machine because once you have taken screws out of the back there are plastic lugs on the inside of the casing that you have to locate, my advice is to oil all the parts that you can see or take it to a sewing machine shop
10/21/2013 5:10:05 PM • Janome 4052LX... • Answered on Oct 21, 2013
Help! My janome harmony 4052 will not stitch
The ziz-zag wdith regulartor might be switched off. try turning the knob. I hope this helps :)
8/18/2013 9:00:58 PM • Janome 4052LX... • Answered on Aug 18, 2013
0answers
Manual
Be the first to answer 6/11/2013 11:32:30 PM • Janome 4052LX... • Posted on Jun 11, 2013Be the first to answer
Not manual janome 4052
I'm not understanding your problem, can you please explain it a little bit more clearly?
4/3/2011 10:47:00 AM • Janome 4052LX... • Answered on Apr 03, 2011
Manual for janome 4052 harmony sewing machine
You can get the manual on the link below.
http://www.managemylife.com/mmh/owner_manuals/18625/KENMORE-Mechanical-Sewing-L0306431?brand_name_search=385.4052
Good Luck please rate 4 thumbs up and please leave a testimonial
3/27/2011 9:52:33 PM • Janome 4052LX... • Answered on Mar 27, 2011
Needle keeps hitting bobbin case when trying to
If the needle is hitting at the low spot when its lowered, the needle is bent or not fully pushed up into the needle bar, could be timing of the needle bar as well.
1/15/2011 8:16:22 PM • Janome 4052LX... • Answered on Jan 15, 2011
Where can I get a manual for the Janome 4052
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=3122&option=com_virtuemart&Itemid=54
11/16/2010 6:36:30 PM • Janome 4052LX... • Answered on Nov 16, 2010
Where do you oil this
Welcome to FixYa! on the list below is the steps to oil your sewing machine.
  1. Remove the screw from the top of the Janome face plate with a small flathead screwdriver. The face plate is on the top of the sewing machine directly above the needle.
  2. Pull the face plate up and away from the sewing machine gently.
  3. Face the sewing machine as if you were about to start sewing.
  4. Locate a small cylinder attached to the side of the sewing machine facing you that had been covered by the face plate. Apply one or two drops of oil to the top of this cylinder.
  5. Locate a small square that is directly above the needle of the machine, also previous hidden by the face plate. Apply one or two drops of oil directly above and below this square.
  6. Replace the face plate and tighten the screw.
  7. Open the hook cover of the sewing machine as if you were changing the bobbin. This area is located directly under the needle.
  8. Remove the bobbin case by grasping the lever on the case and gently pulling the case out from the machine.
  9. Remove the hook ring and the hook. These two parts are behind the bobbin case and should come out easily.
  10. Apply one drop of oil to the center of the hole the bobbin was removed from.
  11. Replace all of the parts you removed from the sewing machine.
Good luck
11/9/2010 8:35:34 PM • Janome 4052LX... • Answered on Nov 09, 2010
I have an old Janome Mystyle 30, which is still
Unfortunately Janome don't provide links to their user manuals, so the only option is to buy one. I cannot find any free examples elsewhere, but this supplier has what you need at a reasonable price. If you find that you cannot eventually get the tension correct, then your machine is worn or out of adjustment and will need servicing. A smooth running machine is vital for consistent tension, so make sure that you have cleaned out the lint from the mechanism and applied sewing machine oil as advised in the owners manual.
Hope that I've been of some assistance and that you quickly solve your tension teaser! Please take a moment to rate my reply.
9/17/2010 7:39:19 AM • Janome 4052LX... • Answered on Sep 17, 2010
I have JANOME NEW HOME MYEXCEL 18W-MW3018 FREE ARM SEWING MACHINE.
Question edited for clarity. Question moved from Computers to Janome. There seems to be different versions, perhaps country versions USA and Australia. Some have 'New Home', some don't. There is a manual in the link. https://www.google.com/search?q=JANOME+NEW+HOME+MY+EXCEL+18W-MW3018 ..
11/20/2022 5:23:26 PM • Janome Sewing... • Answered on Nov 20, 2022
I would like to know how the tensioner assembly parts fits together on an old Janome sewing machine please?
Unfortunately that is the serial number not the model number. The videos in the link might help, but all the parts schematics work on Model Numbers. https://www.google.com/search?q=janome+upper+tensioner+replacement+parts ..
11/16/2022 11:55:59 PM • Janome Sewing... • Answered on Nov 16, 2022
Janome 4052LX Mechanical Sewing Machine Logo
23 questions posted
Top Janome Sewing Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
oil
  • Sewing Machines
