20 Most Recent PfaFF Tiptronic 2030 Questions & Answers
2answers
My 1222e is frozen
1222E/SE Has "Stopmatic" and disengages the machine for bobbin winding. You can't use the crank and needle is locked. Place your lifter bar to the horizontal level (work turning while needle is down), this will engage the machine.
5/17/2020 7:05:23 PM • PfaFF Tiptronic... • Answered on May 17, 2020
How to replace bulb onPfFF TIPTRONIC 2030
To change the bulb in the Pfaff Tiptronic 2030, you need the bulb remover that was in the original accessory package. Push the bulb remover up into the sewing machine (at the bulb) as far as it will go. Rotate the tool (and the bulb) one-half rotation counter-clockwise. Bring the tool and the bulb down and remove the bulb from the remover tool. To put the new bulb back in, put it into the diagonal holder until the pins engage. Push the bulb up into the lamp holder of sewing machine as far as it will go. Rotate the bulb one-half rotation clockwise. Remove the bulb changer tool. The bulb should remain in the sewing machine. This, https://www.sewingpartsonline.com/bulb-remover-412570101.aspx , may be the correct replacement for the tool. Pfaff has many of their sewing machine manuals on their machine support page. The Tiptronic 2030 support is here: http://www.pfaff.com/en-US/Support/272 . The current link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Tiptronic_2030_2040-manual-EN.pdf?ext=.pdf . See page 139 (132 of the PDF) for the directions to change the bulb. I hope this helps. Cindy Wells
5/14/2019 5:15:39 PM • PfaFF Tiptronic... • Answered on May 14, 2019
0answers
When was this machine sold new in the Pfaff dealerships?
From info I could find, it might have been made in the late 1990's or early 2000's. You can search eBay and other seller sites to see if any have sold and how much they cost. ...
12/14/2015 5:56:40 PM • PfaFF Tiptronic... • Answered on Dec 14, 2015
The top left side piece has come off my machine. I need directions of reattaching it back on my machine. It is connected to the machinery the wire connecting to the light bulb.
How did it come off? What was holding it on there to begin with? Screws? Glue? If it's a clean break it might be possible to weld it back together.
6/1/2015 4:32:52 PM • PfaFF Tiptronic... • Answered on Jun 01, 2015
I suspect broken threads are trapped inside the thread route in the tension mechanism. Can I open and clean out?
I suggest turning the tension down to zero and using a crisp dollar bill to try flossing the tension disks. You can also try using un-waxed dental floss to try to floss out the trapped threads.
3/3/2015 1:44:06 AM • PfaFF Tiptronic... • Answered on Mar 03, 2015
How do I and where do I put a replacement bulb in my tiptronic 2030
here is a link for a manual. the information should be in it Instruction Manual Pfaff 2030
12/16/2014 1:25:01 AM • PfaFF Tiptronic... • Answered on Dec 16, 2014
Why when the Foot pedal is pushed all the way down does it click and only allow th machine to go at a very slow speed?
Check to see if there is something caught up in the foot pedal, like a scrap of fabric. That could be enough to prevent you from fully closing the pedal. Disconnect the pedal from the machine and from the wall. Holding the pedal in your hands, squeeze it closed as far as you can. Release. It should pop open. If it does not, then the pedal springs may be broken or worn out.
8/2/2014 12:49:06 PM • PfaFF Tiptronic... • Answered on Aug 02, 2014
2040 tiptronic board replaced
I would take the machine to someone else and see what they say.
5/6/2014 4:05:06 PM • PfaFF Tiptronic... • Answered on May 06, 2014
My 7570 will not run, the light is on but it will not sew
Disconnect the foot control. Turn the handwheel to see if it will turn over freely. Next, power up the machine and press the 'needle down/up' button a few times.. If that works, things are looking promising and the issue is most likely the foot control. If you are able to try your foot control on another Pfaff. If your foot control is not working, most likely it will be the carbon tracer pins inside the foot control. These can be purchased for a few dollars. Skill level to fit them is moderate..... you may break the pins if you do it incorrectly. Alternatively, get a quote for a repairer to do it. Takes 5 minutes.to do.
4/29/2014 12:57:03 PM • PfaFF Tiptronic... • Answered on Apr 29, 2014
0answers
Sewing Machines Logo
106 questions posted
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • PfaFF Sewing Machines
Most Popular Question
pfaff tiptronic 2010
  • Sewing Machines
