20 Most Recent Simplicity Denim Star SW210 Questions & Answers
your question is put under the sewing machine name of
simplicity denim star sw210, so that is the links I'm going to supply
for a manual,, but the manual is not free, I don't know where you can
get one for free
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw210.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-denim-star-sw210-download.aspx
Simplicity Denim... | Answered on Sep 21, 2018
threads and fluff get jammed around the rotating shafts and act as a brake to moving parts
Take the machine in for a service
Simplicity Denim... | Answered on Nov 10, 2015
The "N" on your stitch dial should point or line up with the "A" on your stitch dial. It should now make a straight stitch. Hope this helps.
Simplicity Denim... | Answered on Nov 09, 2015
sounds like needle /hook timing is out
with the needle all the way down and is just about to come up the hook of the bobbin case should be just about at the eye of the needle and just above the eye of the needle
the needle should be in so that the groove in the needle is facing away from the hook and the small cut away is at the hook
timing is affected by loosening the screw on the needle shaft crank arm and adjusting the shaft up or down to position the needle correctly in relation to the hook
the condition of the thread is important as old thread will laminate and the hook will split the thread
Simplicity Denim... | Answered on May 23, 2015
Several things can keep your machine from turning. Thread can be jammed in the hook area, around the shaft by the hand wheel as well as near the take up lever. It is also possible you can have the machine in bobbin wind mode. That would be the first place to check.
Start with removing the bobbin then the bobbin case or bobbin basket.
Try to move the hand wheel back and forth as you do this. Then remove the cover that holds the hook in place. Remove the hook if this does not fix your machine you may need to take it in for service.
Simplicity Denim... | Answered on Oct 13, 2014
What are you needing help with?
Simplicity Denim... | Answered on Feb 14, 2014
I believe this is manufactured by Brother, check at your fabric shop if they can order the part.
Simplicity Denim... | Answered on Dec 14, 2013
Change the needle first failing that you will have to have the machine retimed
Simplicity Denim... | Answered on Oct 31, 2013
there could be a broken part inside, the machine needs to be serviced to find out what happened
Simplicity Denim... | Answered on Oct 21, 2013
Possibly your cord or foot control are bad. It could also be the motor that is not working. Before replacing all those parts take it to a professional to check where your problem is. I use a test panel that allows me to safely short out parts that will then light a light when the offending part is bypassed with a jumper wire.
Simplicity Denim... | Answered on Oct 13, 2013
Simplicity Denim Star SW210 Logo
57 questions posted
Top Simplicity Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Simplicity Sewing Machines
Most Popular Question
machine runs slows down stops will
  • Sewing Machines
