20 Most Recent Simplicity Serge Pro SW432 Mechanical Sewing Machine Questions & Answers
The most common troubles with feeddogs not working properly is either lint trapped in between the feed
teeth...remove the needleplate and clean out the lint which may look like felt in extreme cases. or... the presser foot tension is too low, in which case, increase tension...there will be a knob of some sort at the top
of the machine directly above the Presser Foot Shaft. It is a remote possibility that the feeddog height needs adjusting ...it will have been a major trauma of a severe
jam or tugging etc to cause this. As it would almost certainly result in other timings being affected and particularly in the case of a
Serger/Overlocker, the added risk of breaking loopers (expensive), I would recommend a service by suitably
qualified technician to restore all to optimum condition.
Best Wishes Martyn
Bargain Box in Australia
Simplicity Serge... | Answered on Jun 14, 2020
Check manualsonline.com or manufacturer.
Simplicity Serge... | Answered on Apr 02, 2017
You can purchase a manual for this machine from the following link for $US14.99
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
I can't see it anywhere for free download unfortunately. But you may find that looking at a manual for another 4 thread overlocker may get you started. If you try this link http://www.singerco.com/accessories/instruction-manuals you can look at the free Singer downloads,
try this link for their 654 3/4 thread model http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf
it may give you some help now.
Essentially, to change the stitch width you can either move the lower fixed blade wider to cut less fabric or tighten up the upper and lower looper threads in order to close up the stitching.
Moving the blade usually means opening up the front cover door, putting pressure on the upper blade and swinging it up out of the way. Then you can adjust the lower blade, usally by turning a knob near to it. Sometimes this knob will be marked 1, 2, 3.
Adjusting the looper tensions is done by changing the tension dial settings for the thread needing adjusting. If its a standard four thread overlocker that produces a "marrow" seam it will have two needles and two loopers, upper and lower. Generally on most overlockers, the upper looper will be the second from right tension dial and lower looper will be right most tension dial - turn up one half number to tighten, or down one half number increment to loosen, then test stitch again. The needles shouldn't need adjusting too often.
I usually start with all tension dials on 5, test stitch, then adjust from there. Some fabrics will tunnel (pull in) if the seam is too wide so you need to either move the blade to the left and trim more fabric or loosen off the loopers. Or in the reverse, like you are getting, the threads will hang off the edge.
There is some good serger information on Debbis Cosgrove's pages www.sewing.about.com but if you have never used a serger, then getting the genuine manual is probably best.
Simplicity Serge... | Answered on Aug 18, 2016
Copy this entire link: http://web.archive.org/web/20060508095821/http://www.simplicitysewing.com/ftp/whitepapers/804.pdf Enjoy!
Simplicity Serge... | Answered on Aug 14, 2016
Sergers do pretty much have a certain function--to finish raw edges, although there are some other decorative things you can do with a serger if it has the capability. Download the pdf file at this site to get some ideas: http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB8QFjAA&url=http%3A%2F%2Fwww.peggyddesigns.com%2Fpdf%2FYOU_DID_THAT_WITH_YOUR_SERGER.pdf&ei=eq9sVczgLMbtsAWOroHIDw&usg=AFQjCNEaebGu1AksU57pm61P6mvGGcS4VA&bvm=bv.94455598,d.b2w You can also join some sites that will email you projects every week that can be made on a serger.
A serger is great for making t-shirts (stretchy fabric), tablecloths, napkins, placemats, etc. The rolled hem is nice! And, yes, you can make quilts although it is best to use a sewing machine when intricate stitching of pieces require that the points meet, and the 1/4 inch seam is pertinent to the design. A serger does do a great quilt by serging strip pieces together where the 1/4 inch seam allowance and matching points are not a requirement. It will put a strip-pieced quilt top together very quickly. (Its really quick if you purchase the precut Jelly Roll fabric.) But you will need to figure out how to quilt the top, batting, and backing together using something other than a serger--or pay someone to do it for you.
Or try making a Quilt as You Go quilt where you would serge the top strip, batting, and backing strip all together. When you are finished putting the quilt together, all you will need to do is add the binding--the first part you can use a serger, but when you flip the binding over to the front side to finish, you'll probably want to handstitch it.
How To Sew An Easy Strip Quilt
40 Free Jelly Roll Quilt Patterns 5 New Jelly Roll Quilts
Quilt as You Go Strip Quilt National Quilters Circle
Simplicity Serge... | Answered on Jun 01, 2015
you need a set of allen wrenches... a very small one works
Simplicity Serge... | Answered on Oct 15, 2013
Simplicity Serge Pro SW432 Mechanical Sewing Machine Logo
110 questions posted
Top Simplicity Sewing Machines Experts
Douglas Plant
Douglas Plant
Chris Wetmore
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Simplicity Sewing Machines
Most Popular Question
find free operators manual
  • Sewing Machines
