20 Most Recent Singer 2732 Mechanical Sewing Machine Questions & Answers
Get in touch with the store!
Singer 2732... | Answered on Sep 07, 2017
If you have the black bobbin case you must make sure you use only a good mercerised thread, there should be enough gap between the edge of the bobbin case and the silver adjuster to allow the thread to pass through, if there is not then you must slacken off the two screws and move it over a fraction.
Singer 2732... | Answered on Oct 30, 2016
Search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer Support number.
Singer 2732... | Answered on Jan 20, 2016
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
Singer 2732... | Answered on Mar 29, 2015
  1. Using a doubled piece of fabric similar to what you have in mind for your project, sew a seam on the diagonal-pulling the fabric on the diagonal to break the threads. (Ideal tension would either break neither thread or break both threads. So, a single breaking thread signals that the tension needs adjusting.)
  2. Snap out the faceplate to remove it & to gain access the bobbin area below the sewing needle.
  3. Remove the bobbin case & bobbin-lifting the hinged latch that you would to wind a new bobbin-leaving the bobbin in the case. (You need it in there to feel the tension as you adjust it.)
  4. Using a small screwdriver, very slightly turn the screw on the side of the bobbin case clockwise to increase tension; counterclockwise to decrease tension.
  5. Pull the bobbin thread while you hold the bobbin in its case & feel the thread's tension. Too tight of tension would prevent the thread from dispensing (& possibly break), but too loose of tension would allow the bobbin to fall out of its case.
  6. Return the bobbin case to the sewing machine & close the faceplate.
  7. Repeat this whole routine from Step One on the doubled fabric. Stitching should run along both the top & the bottom in the same way-locking in the center. A diagonal pull of the fabric should show which thread(s) break(s). Repeat Steps Two through Four to only adjust the screw aside the bobbin case in order to allow the threads to lock in the center of the fabric with both threads having the same break or no-break result.
Singer 2732... | Answered on Nov 29, 2014
There are three causes. Make sure your needle is all the way up in the needle clamp, and the flat side it on the back (if your bobbin is in the front of the needle).
If it is, then your timing is out of synch, and you will need to get a technician to fix it.
Singer 2732... | Answered on Nov 19, 2014
You can download your manual free at http://www.singerco.com/support/instruction-manuals/search.
Singer 2732... | Answered on Nov 03, 2014
  1. it sounds like the filter capacitor has failed. the capacitor is usually located inside the foot control but may be inside the machine itself.
try taking the foot control apart (dis-connect from power first). you should see a component rectangular in shape connected to the wires in the foot control. dis-connect this component (it will not adversely affect the running of your machine) and then re-assemble the foot control and test. if this did not fix the problem see a tech.
scott.
Singer 2732... | Answered on Jun 26, 2014
try changing the needle
try rethreading the machine top and bobbin with a different thread
try a different bobbin--and then make sure the bobbin is turned the
right way.
make sure the to thread has not come off the thread take up lever
Singer 2732... | Answered on Dec 21, 2012
it's a problem with the thread take up lever, either put a small
piece of tape on the take up lever or take a pair of pliers and
carefully place a cloth over the take up lever and close the take up
lever a little but don't damage the take up lever
if you don't have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/1313_2732.pdf
Singer 2732... | Answered on Dec 19, 2012
Singer 2732... | Answered on Dec 16, 2012
It's out of time. Take it in for repair. (get it cleaned, lubed and have the belts checked while you are there)
Singer 2732... | Answered on Dec 04, 2012
Singer 2732 Mechanical Sewing Machine Logo
76 questions posted
Top Singer Sewing Machines Experts
tsalagi152
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
singer 2732 sewing machine will not pick
  • Sewing Machines
