20 Most Recent
White Sewing 972 Mechanical Sewing Machine Questions & Answers
972 Mechanical Sewing Machine: I have a problem with Singer 972 sewing machine. T...
Always thread a sewing machine with the presser foot up and this will eliminate what looks like a loopy bobbin thread.
If you thread with the presser foot down, the tension control is not open to accept the thread as it is designed to do.
Then when you sew, the tension cannot control the top thread and the bobbin thread pulls the loose top thread to the bottom of the fabric.
Normal setting for the tension is usually mid-range ( 4 or 5).
Thread won't pick up on a White 6477 Industrial Sewing Machine.
While turning the handwheel towards you monitor the needle when it begins to rise. Look where the needle and the hook (under the bobbin) are. The hook has to cross the needle at just the right time (timing). This is the most likely area that is wrong. If the timing isn't right then something caused this which means needing a repairman to fix.
Need threading diagram for model 988 white sewing machine?
You can watch here thousand of Movies, Shows. Now you can easily Activate Amazon by visiting amazon.com/activate you can watch prime videos anywhere on your device. Users need to create an Amazon account if they don't have an Amazon account and enter the Amazon my tv activation code to watch Amazon prime videos on your device.
https://www.amazncomamazn.com/
Dial wont turn on White sewing machine 2037
Most likely the grease used has gotten hard. Take off the top and use your hair dryer to warm it up and attempt to turn back and forth. Afterwards, spray some synthetic spray in this area of your machine.
