20 Most Recent Cobra FRS 307 (14 Channels) 2-Way Radio Questions & Answers
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.wedophones.com/Manuals/Cobra/FRS%20-%20GMRS%20Accessory%20Manuals/FA-CF_INSTRUCT.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Cobra FRS 307... | Answered on Nov 08, 2011
GO TO THE FCC WEBSITE:
https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm?calledFromFrame=N
ENTER THE FCC ID # YOU MUST ENTER IT CORRECTLY.
FOR INSTANCE...MY FCC ID # IS G9H3-5810 ENTERD CORRECTLY WOULD BE ON THE FIRST LINE
G9H AND THE NEXT LINE 3-5810.
TRY THIS FIRST UNTIL YOU GET USE TO IT AN IT WILL BRING UP ANOTHER MENU. UNDER DISPLAY EXHIBIT CLICK ON DETAIL
THEIR YOU WILL SEE BLOC DIAGRAMS,SCHEMATICS ETC. HOWEVER NOT EVERY RADIO WILL DISPLAY THIS,IF THE COMPANY PAYS EXTRA $ TO THE FCC CERTIAN THINGS WILL NOT BE DISPLAYED LIKE SCHEMATICS.
THERE IS A WAY AROUND THIS ALSO, THE US PATENT OFFICE. TYPE IN THE PANTENT NUMBER AND EVERYTHING WILL BE DISPLAYED, IF YOU CAN FIND THE PATENT ID #.
HOPED THIS HELPED
KEVIN
Cobra FRS 307... | Answered on Dec 30, 2007
PTT could be at fault as could just the lamp if it still transmits.
Cobra Radio... | Answered on Jul 17, 2020
CB is CB. If it's FM it is good for UK and USA. Old stock and obsolete though.
Cobra Radio... | Answered on Jun 29, 2020
https://www.worldwidedx.com/threads/cobra-2000gtl-carbon-dating.146028/
Manufacturer replied to someone that couldn't date models by serial number, but that they began building the model in 1978.
Cobra Radio... | Answered on May 30, 2020
Aquire operation-installation manual from manualslib.com. Mount the antenna on front or side for easy route of coax. Connect red wire to fuse box terminal label ACC or power by ignition. Place power box for best routing of cable to hand unit, under dash, under seat, on left side, etc. Borrow a watt meter to tune SWR of antenna for last step. Happy travels.
Cobra Radio... | Answered on Jan 22, 2020
It is very likely that you haven't got the same CTCSS or DCS codes matched. Try turning them off on both radios.
Cobra Radio... | Answered on Nov 10, 2019
The squelch control is probably damaged. They aren't very sturdy. Controls on radio's these days don't take a lot of abuse. Luckily, the replacement parts can usually be found on EBAY and aren't expensive but you will have to install it yourself or take it to a shop and have it done if you aren't technically inclined. It's not a difficult job to do but a shop will still probably charge more than the radio is worth to do the repair. If you can find a HAM nearby, you might be in luck.
It's likely that a bulb has died. This isn't an expensive repair although a radio shop probably won't look at it for at least $75. If you are talking about the display being out, that could be expensive. If the radio is old, then the part probably isn't available anymore. It may be possible to fit something else into the display. I am not familiar with this particular radio. The likely problem is a burnt out series resistor or more likely a bad solder joint on the digital display. THAT should be an easy fix.
The display may have failed.
Cobra Radio... | Answered on Oct 31, 2019
That's a confusing question. Device id is the FCC device ID number and means it has been approved to transmit in the USA. It has nothing to do with model. So, in terms of a radio device, it means nothing to a tech or a way to get parts or even a battery. The device ID is typically located on the back of a radio or under the battery. Could you ask what you are looking for?
Cobra Radio... | Answered on Oct 04, 2019
Hi Anonymous, as you say, your batteries have little or almost no charge capacity
That's why the charger lights remain on
Simply replace the batteries.
I hope you can solve the problem
Greetings Franco Dosil
Hola Anonimo, por lo que comentas, tus baterias tienen poca o casi nula, capacidad de carga
Espor eso las luces del cargador permanecen prendidas
Simplemente, reemplaza las pilas
Espero puedas resolver el problema
Saludos Franco Dosil
https://fccid.io/BBOLI4900/User-Manual/USERS-MANUAL-751014
Cobra Radio... | Answered on Sep 26, 2019
the issue is that this radio has an audio boost control function, Dynamike. That is likely the issue, the two are working against each other. You can see if the power mic you have will work if you dial the Dynamike all the way down, but you might have to live with the stock mike.
Cobra Radio... | Answered on Sep 24, 2019
What is the swr? This can impact the receiver. However, the tuning coils for receive and transmit are close to each other and someone most likely turned the receive coil instead of the transmit coil. The coils that are adjustable that affect receive are 13, 15 and 3. 3 is the coil that is close to the transmit section. You may want to have it realigned.
Cobra Radio... | Answered on Sep 13, 2019
If it "keys up" without a mic plugged in, try plugging the mic into the radio and see if it stops. Some radios require the mic to be plugged into it to operate properly. If it is keyed up with the mic plugged into it, try unplugging the mic and see if it stops. If it does stop when you unplug the mic, either the switch in the mic is stuck/went bad or there is a wire shorted in the mic cord to radio plug. Make sure pins 3 and 4 on the mic plug are not shorted. A continuity meter will tell you. If the mic is keyed, pins 3 and 4 will show a short, if the mic is not keyed, pins 3 and 4 should not show a short. If the mic is functioning normally but the radio is still keyed up then there is something in the radio that is shorted.
Cobra Radio... | Answered on Aug 29, 2019
Use scissors? .... please explain what you mean.
Cobra Radio... | Answered on Aug 25, 2019
Cobra FRS 307 (14 Channels) 2-Way Radio Logo
4 questions posted
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
looking schematic trace power
  • Radio Communications
