20 Most Recent Copystar CS-1510 Copier Questions & Answers
check the top original feeder switch they get pulled wrong way and stick insert a thick piece of cardstock in original feeder slot and push it in until the switch is able to move freely
Copystar CS-1510... | Answered on Jul 12, 2017
remove drum , clean and re insert .
Copystar CS-1510... | Answered on Jan 22, 2013
Use the link below to download the manual from the maufactures website. The link is for the KM-1510 which is the same as the CS-1510.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=5051&rid=2076
Copystar CS-1510... | Answered on Jun 14, 2012
churn up the toner in service mode press10871087 then 130 then start button it will start with 10 and go on to GD restart the machine that's it
Copystar CS-1510... | Answered on Aug 19, 2011
This is the polygon engine (laser writing system) which is weary
Contact your service department to replace it, or wait until it fails ...
Copystar CS-1510... | Answered on May 13, 2011
what do E310 mean on a panasonic copier 7722
Copystar CS-1510... | Answered on May 05, 2011
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Copystar CS-1510... | Answered on Apr 18, 2011
there are no parts available that i am aware of. when i have a laser unit go out on a machine that i service, i send it in to have it rebuilt. quite pricey however.
razors
Copystar CS-1510... | Answered on Mar 10, 2011
Press and hold stop button the take the reading
Copystar CS-1510... | Answered on Feb 03, 2011
It seems the problem of Spacer. in your Ink Unit. In INK Unit there are two black bearing (called spacer) are used at the both end of INK Unit. Try to replace those spacers. or send me the print out of your machine.
Copystar CS-1510... | Answered on Jan 19, 2011
according to you your copier is noisy.
To avoid it you can clear the toner cartridge first. dirty cartridge make noise.
You have to clear the roller section also.
You can contact the customer service.
Copystar CS-1510... | Answered on Jan 06, 2011
Copystar CS-1510 Copier Logo
72 questions posted
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Timothy Van Der...
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Copystar Office Equipment & Supplies
Most Popular Question
copies black toner back copies
  • Office Equipment & Supplies
