20 Most Recent Copystar CS-2030 Copier Questions & Answers
use the new mac driver for any black and white machine it will work. the new driver i think is 3.0.
www.copystar.com
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Copystar CS-2030... | Answered on Jul 23, 2017
Only copiers fitted with a duplexing unit will automatically make a double sided copy. I assume yours does not have this accessory.
You can always make two sided copies manually. You need to first work out the paper path, so mark one piece of paper with an arrow showing the top and the direction the sheet was placed on top of the paper feed tray. Make a copy and you will now know whether the top or bottom of the paper as loaded gets printed on. Now place that sheet back in the paper feed tray again with the arrow face down in the paper tray, but still pointing in the same direction as before. Print side two and you will now have a double sided copy. If the reverse of the copy is facing the wrong way then you know that the paper needs to go into teh paper tray with the arrow facing you. Hope this makes sense, but it just needs a couple of trial runs to get to understand which was round to put the paper back in for the revers side to be printed. Always keep the final successful double sided copy, marked up for future reference, as it is so easy to forget which way to put the paper back in several weeks later.
Copystar CS-2030... | Answered on Nov 02, 2015
Call a local service company and they can replace the needed parts and reset the message
Copystar CS-2030... | Answered on Oct 26, 2014
as i said, buy a cartridge
Copystar CS-2030... | Answered on Jun 06, 2014
if you are trying to clear the service/maintenance counter press 10871087 which will enter service mode type 251 and select clear using up/down keys then the start button. this will clear your maintenance counter. hit stop key 2 times the up arrow to 001 and start key. this will restart the machine. hope this is what you were looking for.
Copystar CS-2030... | Answered on Apr 21, 2013
http://techbravo.net/sharpftp/2030-errors.pdf
Copystar CS-2030... | Answered on Jan 30, 2013
C710 Toner sensor problem
• The sensor output voltage is outside
the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Try removing and refitting drum and toner.
if this does not help you may have damaged your toner cartridge or the sensor
Copystar CS-2030... | Answered on Nov 19, 2012
perform developer calibration... go to SP mode 05-0 start
Copystar CS-2030... | Answered on Nov 25, 2011
Don't panic ! the copier has just reached the number of copies to display the message. There are parts inside that are only good for so many pages. Depending on what has reached the number it might mean slightly degraded copies or it will rub out of toner or perhaps a waste toner storage is full.
Basically the only time it is a emergency is when smoke is coming out of these.
Copystar CS-2030... | Answered on Sep 15, 2011
What??????????
Copystar CS-2030... | Answered on Aug 20, 2011
run 10871087 the press 130 then START it will start from count 10 to till it shows gud. thats it
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Copystar CS-2030... | Answered on Apr 05, 2011
The fuser (hot rollers) fingers may be broken or bent. Try feeding the paper from a different paper cassette also. Good luck.
Copystar CS-2030... | Answered on Feb 26, 2011
Press 1087 1087 until machine shows U000. enter 163 press start. scroll to execute then press seart
Copystar CS-2030... | Answered on Feb 25, 2011
Copystar CS-2030 Copier Logo
79 questions posted
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Timothy Van Der...
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Copystar Office Equipment & Supplies
Most Popular Question
all error code list
  • Office Equipment & Supplies
