20 Most Recent
Columbia Telecommunications Group SVND-14S (14 Channels) 2-Way Radio Questions & Answers
Transmit no recieve
Mike 2 things are needed to get 2 radios comunicated 1 channel, 2 the Squelch code, if both are the same in each radio (same chaennel and same code Ex. Ch 5 Code 22) the radios must to be comunicated.
Press the menu key to change each of this features
The Squelch code can be PL or DPL, no matter wich one are you using, just need to be the same.
2/15/2007 5:54:00 PM •
Columbia...
Answered
on Feb 15, 2007
Does columbia telecommunications group,inc have a
The last known contact information for Columbia Telecom is as follows:
Headquarters Location
174 Milbar Blvd., Farmingdale, NY 11735, United States
(631)501-5000
http://www.columbiatel.com
The bad news is, the company itself doesn't seem to exist anymore, other than bad consumer reviews and issues with company practices. The website is no longer valid either.
4/29/2013 10:57:19 PM •
Columbia...
Answered
on Apr 29, 2013
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
3 days ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
