20 Most Recent Columbia Telecommunications Group GMRS/FRS 2-Way Radio Questions & Answers
I HAVE A MODEL EB-1 ELECTRONIC BIBLE AND I CAN'T
E-mail me at [email protected] and I'll see what I can do to send you A copy of my original owners manual. Thanks, James
1/28/2015 4:11:01 PM • Columbia... • Answered on Jan 28, 2015
I NEED A USER MANUAL FOR MY GM3W
Go to this site and you should be able to download your manual for free.
9/6/2014 1:58:57 AM • Columbia... • Answered on Sep 06, 2014
Columbia two radios have been stored away for at
First check the insides of the radios. If they have been corroded by battery acid you most likely cannot recover them. Check that before you scrounge the Earth for obsolete batteries.
10/14/2013 12:03:37 AM • Columbia... • Answered on Oct 14, 2013
2answers
Columbia Telecommunications Group Manual
http://safemanuals.com/ please rate me let me knoe if i could help.
6/10/2012 7:38:30 PM • Columbia... • Answered on Jun 10, 2012
I have some frs14nd radios and am looking for
I couldn't locate a battery pack specifically marketed for the FRS14ND, but information I did find indicates that your radios will operate on standard AAA batteries.
Bill B
11/12/2010 3:21:04 PM • Columbia... • Answered on Nov 12, 2010
My gmrs 1 will not turn on with batteries
Are the batteries fully charged? Are the batteries inserted with the correct polarity? If still no job return them to the store for an exchange
4/30/2010 7:31:13 AM • Columbia... • Answered on Apr 30, 2010
Do they have batteries or a charger
Normally work with 4 AAA batteries. Some models have a charger capability.
8/21/2014 1:24:15 PM • Columbia... • Answered on Aug 21, 2014
3answers
Does columbia telecommunications group,inc have a
The last known contact information for Columbia Telecom is as follows:
Headquarters Location
174 Milbar Blvd., Farmingdale, NY 11735, United States
(631)501-5000
http://www.columbiatel.com
The bad news is, the company itself doesn't seem to exist anymore, other than bad consumer reviews and issues with company practices. The website is no longer valid either.
4/29/2013 10:57:19 PM • Columbia... • Answered on Apr 29, 2013
I have a pair of walkie talkies, rechargable, but one of them wont work with the battery pack. Both battery packs work in the other one, but this one will only work with 5 AAA batteries. Any ideas out
If your rechargeable battery pack takes a different battery tray than the alkaline, you possibly have a bad connection in the battery tray. If they appear to use the same battery contacts, look at where the rechargeable battery touches compared to the alkaline. There may be a problem in this area. Clean all contacts with a pencil eraser to insure your radio is free of debris on the contacts.Best regards.
4/1/2012 12:24:22 AM • Columbia... • Answered on Apr 01, 2012
Radio Reed only odd frequency issue !
US FM radios freq are always on odd freq, there are no even freq. link copy and paste https://www.fcc.gov/media/radio/fm-frequencies-end-odd-decimal
3/29/2023 4:53:21 PM • Radio... • Answered 16 hours ago
I need a manual for a GME TX610
If you're looking for a manual for the GME TX610, there are several ways you can obtain one. The GME TX610 is a handheld UHF CB radio that was manufactured by GME Electrophone, an Australian company that specializes in communication equipment. One option is to visit the GME Electrophone website and navigate to the "Support" section. Here, you should be able to find user manuals for their products, including the GME TX610. Another option is to reach out to GME Electrophone's customer support team and request a manual for the GME TX610. They may be able to provide you with a digital or physical copy of the manual. If those options don't work, you can also search online for a digital copy of the manual. There are several websites that offer manuals for a wide range of products, including the GME TX610. However, be sure to download the manual from a reputable source to ensure that it's accurate and up-to-date. I cannot provide any website as it is legit, you have to search by yourself and ensure its validity. By following these steps, you should be able to access a manual for the GME TX610 and learn how to use its features and functions effectively
3/26/2023 9:38:57 AM • Radio... • Answered 3 days ago
How to faulty find gr500 motorolla repeater when repeater channel is not working
1. Check the power supply to the repeater to ensure it is plugged in and working properly. 2. Check the antenna connections to ensure they are securely connected. 3. Check the coaxial cable connecting the antenna to the repeater to make sure it is free of any damage or degradation. 4. Check the settings on the repeater to ensure it is configured correctly for the channel. 5. Check the radio frequency of the repeater to ensure it is correct for the channel. 6. Check for any interference in the area that may be causing the repeater channel to fail. 7. Check the signal strength of the repeater to make sure it is strong enough to transmit the signal. 8. If possible, try another repeater in the same area to see if it is having the same issue.
3/17/2023 10:44:16 AM • Radio... • Answered on Mar 17, 2023
2answers
How to fix Code 8001009 on PS3
The headset and the bluetooth adapter might not be able to work on your PS 3 console at all and in not compatible either.
3/11/2023 8:39:08 AM • Radio... • Answered on Mar 11, 2023
Error rx or error tx for vhf radio Ic A210 in ultra light aircraft Appears on display What is defective?
ill suggest your antenna or a connection to it. rx is receive and tx is transmit
3/8/2023 1:58:09 PM • Radio... • Answered on Mar 08, 2023
Columbia Telecommunications Group GMRS/FRS 2-Way Radio Logo
Popular Tags
9 questions posted
Top Columbia Telecommunications Group Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Columbia Telecommunications Group Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
Columbia Telecommunications... Radio Communications
  • Columbia Telecommunications... Radio Communications
Most Popular Question
model eb 1 electronic bible
  • Radio Communications
