20 Most Recent Clymer Suzuki 2-225 HP Outboards Includes Jet Drives 1985-1991 Questions & Answers
Turn the carburetor upside down. The float should be level with the bottom of the carburetor.
Clymer Suzuki... | Answered on Oct 28, 2018
Replace it. They are just a simple contact switch . Go to the local auto parts store and pick one uo.
Clymer Suzuki... | Answered on Jul 11, 2018
With or without remote control??
Disconnect the black/red wire from the CDI, if you have sparks, kill circuit shorted.
No spark: check coils
1 . The two pulser coils are located at 1 80┬░angles to each other and the
condenser and battery charge coils are also located opposite of each other
under the flywheel.
2. Remove the engine cover.
3. On models equipped with electric starters, disconnect the negative
battery cable.
4. Disconnect the connector and black ground wire.
5. On the No. 1 pulser coil, connect the digital multi meter between the
black/red wire terminal in the connector and the black ground wire. And the
No.2 coil between the white/green wire terminal in the connector and the
black ground wire. Resistance should be 260-380 ohms.
6. On the condenser charge coil, measure the resistance between the
black/red and green wires. Resistance should be between 1 70-250 ohms.
7. If the resistance reading is not within specification, replace the faulty
coil.
8. On the battery charge coil, measure the resistance between the
yellow/red and yellow wires, red and yellow wires (DT1 5MC) or the red and
yellow wires (DT15CE). Resistance should measure between 0.2 and 0.5
ohms.
9. If the resistance reading is not within specification, replace the faulty
coil.
Clymer Suzuki... | Answered on Nov 14, 2017
Have a gap of about 0.1mm ( 0.004in)
Clymer Suzuki... | Answered on Oct 02, 2017
Hey Rolin,
..could this be a brass tube? It probably a vent tube..it should not be bent or crimped...
Clymer Suzuki... | Answered on Sep 25, 2017
the manual shows for a 100 :1 mix the ratio is 4 ounces of oil to 3 gallons of fuel
there are two engines and one is 50: 1 ratio so that would be 8 ounces of oil to 3 gallons of fuel
there is a pdf version workshop manual at www.motoren.ath.cx and it gives the ratios for all of the 4hp suzuki outboards and the oil to use
Clymer Suzuki... | Answered on Nov 25, 2016
No it wont overheat !!! Change the solinoides over on the trimand see if you can raise engine and now not lower ! if yes then replace solinoide !
Clymer Suzuki... | Answered on Jun 20, 2014
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Clymer Boating | Answered on Oct 04, 2017
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
I think you have to look at a fuel supply problem. Clogged carbs or bad fuel pump...
Also have a look at your spark plugs...
Clymer Boating | Answered on Sep 25, 2017
clean carbs and check set up !
Clymer Boating | Answered on Jun 04, 2014
Lots of things needed when you go for kayaking. It depends on you and where you want to kayak. If you go for fishing you need fishing types accessory but if you go for tour or adventures you need that types of thing. Considering these things, I will select some materials that you need. They are those :
Dry Bags and Dry Box ,Bilge Pump or Sponge ,Lightweight Tent ,Synthetic Sleeping Bag,Life Jacket,Water Filter or Iodine Tablets,Sunscreen,Watch,Paddle float,Compass (that floats),Towline,Maps and charts in waterproof case,Lip balm (SPF 15+),Insect repellent (as needed),Water in bottles or reservoirs-shielding hat,GPS (loaded with map files,Emergency flares or strobe,Two-way radios (1 in lead, 1 in sweep boat).
To know more about kayak you may visit here
Best Inflatable Kayaks in 2018 List of The Top Selling Models
Boating | Answered on Sep 29, 2020
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Boating | Answered on Aug 29, 2020
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Boating | Answered on Aug 26, 2020
Clymer Suzuki 2-225 HP Outboards Includes Jet Drives 1985-1991 Logo
9 questions posted
Top Clymer Boating Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
suzki 140x settings in mm between
  • Boating
