20 Most Recent
Chase C6A Waltham Antique Ps Bartlett Pocket Watch 18 Size 15 Jewels Gold Filled Circa 1887 Questions & Answers
Have a waltham pocket watch in an illinois case
If you go to the web site "www.antique-pocket-watch.com/waltham-pocket-watch.html", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
Chase C6A...
Answered
on Feb 10, 2010
Pottery Barn. How can I fix a sticking second hand on this pocket watch?
If the second hand is misaligned and binding on one of the other hands the repair is fairly straightforward but will mean opening the case and making an adjustment with the delicacy of a surgeon and without wishing to insult you - if you have to ask how you probably aren't the best person to do the repair, especially if something else is causing it to bind.
I suggest you hand the responsibility to a local professional...
Watches
Answered
on Jan 10, 2021
How do I change your battery natural Raymond watch Number 5420PB
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Watches
Answered
on Dec 25, 2020
AccuTime 4025WMM. How can I charge it?
Often times, we get confused when we finally hear the exact term of website development services apart from the internet developer being used interchangeably. But the thought is broken when you look at this, all your personal confusion can disappear.
Watches
Answered
on Dec 21, 2020
HOW TO CHANGE TIME AND DAY IN KADIO MODEL KD-725A QUARTZ TIMER
KADIO KD-725a manual:
NOTE: on some models buttons START, LAP and MODE are named D, S and M.
Time is defined as 12 hour - AM and PM. 24 hours mode is not available.
SET TIME: Press MODE 3x. Select item with LAP, set value with START.
Finish: press MODE. (return to normal mode - displayin time)
To view date press START.
SET ALARM: Press MODE 2x. Select hour or minute with LAP. Set value with START.
Finish: press MODE.
You can switch alarm on/off pressing both buttons START and LAP together. Status is displayed as a simbol of alarm clock.
STOP RINGING: Press START or LAP to silent alarm. It will ring again after 5 minutes (snooze function). If you dont want alarm to sound again, you should completely turn it off by pressing START and LAP together. Don't forget to turn it on again to wake you up at the next morning.
NOTE: When setting alarm some simbols of days in the week will flash. I can't found any funcionality of this. Obviously alarm can not be set on different day, only for every day.
SPORT MODE - STOP WATCH:
Enter: Press MODE 1x.
Start/stop/pause measuring time by START.
Set time to zero: Press LAP
Return to normal function (displaying actual time): press MODE 1x.
Note: Value of measured time will be saved, until you press LAP. You can jump from normal mode to reenter saved value by pressing MODE once again and continue to measurin time of
your sport activity.
NOTE: Some models have backlight. Models with only one AAA battery have no ligt, on the top is only a metallic strip instead of switch.
Watches
Answered
on Dec 17, 2020
