20 Most Recent Puma Active Collection Dynamic Posh Black Jeweled #PU101122001 Watch for Women Questions & Answers
Dont have that particular watch, but try this.
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Puma Active... | Answered on Mar 07, 2011
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
You should specify the width of the strap or bracelet in mm and look for it in Amazon or any retail store
http://www.amazon.com/Silicone-Soft-Rubber-Watch-Band/dp/B00DU3EX70
A good rubber strap might cost between 10 and 20 USD
Puma Watches | Answered on Mar 19, 2019
Try Googling (puma)(PU911291001U)(manual) without parens.
Puma Watches | Answered on Mar 21, 2018
Puma Active Collection Dynamic Posh Black Jeweled #PU101122001 Watch for Women Logo
10 questions posted
Top Puma Watches Experts
Janelle Schoonover
Janelle Schoonover
ray gallant
Tom Chichester
Are you a Puma Watch Expert? Answer questions, earn points and help others
View Most Popular
Puma Watches
  • Puma Watches
Most Popular Question
puma time touch screen
  • Watches
