20 Most Recent Sterling J3E Hamilton Antique Pocket Watch Questions & Answers
The serial number is usually engraved on the movement. If you open the back of the watch, you should be able to see it.
I looked at the Hamilton pocket watch site (in might be helpful if you visit the site, simply type "hamiltonpocketwatches.com" into your search engine and your will be able to examine photos of a number of movements).
The position and size of the number varies but it shouldn't take to long to find. One of the pictures I found impossible to see the number but the rest I found, although sometimes you had to look quite carefully.
Sterling J3E... | Answered on Jul 23, 2013
Unfortunately no, the only option is to remove the mechanical works and replace it with a quartz circuitry.
Sterling J3E... | Answered on Sep 26, 2011
Several solutions:
Needs cleaning is the best possible reason.
Broken balance due to being dropped is second.
r/
David
Sterling J3E... | Answered on Jan 22, 2010
If your watches case does not have a hinge then pulling the crown out won't do anything but allow you to set the time if it is a stem set watch. If it is a lever set watch then the lever which is under the bezel will need to be pulled out before you can set the time.
On a pocket watch without a hinge the case back and or bezel will unscrew from the case.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Sterling J3E... | Answered on Nov 11, 2009
Pull the wind knob out...it takes a firm pull on mine. You will hear it click, then you have room to pull the movement out towards the hinge. Then close when done, and push the wind handle back in.
At one oclock the lever is pulled out about 1/4" then you can set the time, when finished, push the lever back in.
Hope this helps...george
Sterling J3E... | Answered on Jun 14, 2009
Impossible to tell from that flashed out, badly lit, out of focus shot!!
This is the watch, PLEASE put full name and model into ALL questions. nothing in your title is the 'serial number' so I have edited the question. The serial number is inside the watch case. Fakers will put something on the back to trick you (they did, you thought you had No. 383)
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01N4m87y6q9v5JmCabFQ554q9X6WQ%3A1610754232856&ei=uCgCYMLOM4eu5NoP1oy9qAQ&q=Bvlgari+EGW+30+G+D+383
Onto spotting fakes. Usually, if you have to ask if it's fake, it is. If you bought it on Amazon or eBay or from a guy in a bar, it's fake. On high end watches the strap is silky smooth, no rough edges. Each one takes an hour to polish.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01pPGyirk_gyl3aY9tbxNzXajNFhw%3A1610754295213&ei=9ygCYNG3DIqv5NoP6IK_kA4&q=Bvlgari+EGW+30+G+D+383+spotting+fakes
Value
This is probably the only site I would trust that I can find
https://www.jomashop.com/bvlgari-watches.html
Watches | Answered 22 minutes ago
If the second hand is misaligned and binding on one of the other hands the repair is fairly straightforward but will mean opening the case and making an adjustment with the delicacy of a surgeon and without wishing to insult you - if you have to ask how you probably aren't the best person to do the repair, especially if something else is causing it to bind.
I suggest you hand the responsibility to a local professional...
Watches | Answered on Jan 10, 2021
All about your battery here
https://www.fixya.com/support/r27181038-changing_watch_batteries
All questions on Fixya must have full
make model (what it is)
as illustrated below!
Ray-Ban RX7047 5573 ' eyerim.com
www.eyerim.com > ... > Ray-Ban > Ray-Ban RX7047
Buy Ray-Ban RX7047 5573 prescription glasses online! ' eyerim.com ' ? Free Shipping ? 30 Day returns ? 100% Authentic.
Watches | Answered on Jan 08, 2021
Take it and the parts to a jeweller for advice.
Watches | Answered on Jan 07, 2021
I have a techo king quarte watch needed the right battery for . what's the number
Watches | Answered on Jan 04, 2021
Contact Accutime with your request.
Watches | Answered on Jan 03, 2021
The military do not have a "luxury brand" watch!
Watches | Answered on Dec 30, 2020
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Watches | Answered on Dec 25, 2020
http://home.microtech.com/mikef/Aquatech.htm
Watches | Answered on Dec 22, 2020
Often times, we get confused when we finally hear the exact term of website development services apart from the internet developer being used interchangeably. But the thought is broken when you look at this, all your personal confusion can disappear.
Watches | Answered on Dec 21, 2020
Watch instructions here I think. A full make and model are useful rather than guessing
https://static1.squarespace.com/static/58ca120515d5db2d0e0f609e/t/58da90d4be6594b226a75890/1490718936270/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
Or any of these?
UL 1002 - UL Standard for Safety Electrically Operated Valves ...
standards.globalspec.com > std
Nov 30, 2006 - Find the most up-to-date version of UL 1002 at Engineering360.
Other Standards > Underwriters Laboratory Inc. > UL 1002
www.roadauthority.com > Standards
UL 1468 Direct Acting Pressure Reducing and Pressure Restricting Valves. UL 1469 Backflow special check valves of 3/4-inch (19.1-mm) through 10-inch ...
UL 1002 : UL Standard for Safety Electrically Operated Valves ...
global.ihs.com > doc_detail
UL 1002, 7th Edition, November 30, 2006 - UL Standard for Safety Electrically Operated Valves for Use in Hazardous (Classified) Locations These requirements ...
Kurt S. Adler Replacement Bulb for UL1002, 3 Piece Set, Multi ...
www.amazon.ca > Replacement-Bulbs-Ul1002-Bubble-...
Kurt S. Adler Replacement Bulb for UL1002, 3 Piece Set, Multi, C7: Amazon.ca: Home & Kitchen.
Watches | Answered on Dec 18, 2020
Sterling J3E Hamilton Antique Pocket Watch Logo
13 questions posted
Top Sterling Watches Experts
Bruce Robin
Lisa Christine
Lisa Christine
Marvin
Marvin
Are you a Sterling Watch Expert? Answer questions, earn points and help others
View Most Popular
Sterling Watches
  • Sterling Watches
Most Popular Question
possible convert wind up watch
  • Watches
