20 Most Recent Minolta EP1083 CS/PRO Copier Questions & Answers
explain this
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta EP1083... | Answered on Jun 18, 2016
Check the fuser and or the main power board, if you can find a tech with that sysytem a legacy Minolta machine before they became a Konica Minolta.
Minolta EP1083... | Answered on Mar 09, 2016
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
Minolta EP1083... | Answered on Feb 29, 2016
legacy machine can not print with it
Minolta EP1083... | Answered on Jan 24, 2016
do not under stand
Reset button is located behind the copier. Remove the rear upper cover you will see a circuit board with the machine on depress the small black button on the board., lower left If the code comes back then the exposure lamp is bad that is the bright light under the big glass.
replace the lamp try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Minolta EP1083... | Answered on Nov 21, 2015
Get the developer replaced. and developer unit cleaned. Have a Konica Minolta tech come out and clean the entire machine replace the required parts such as Developer, clear the counters and run the required F8
Minolta EP1083... | Answered on Mar 02, 2015
where the black line being left when after the drum or before the fuser THe hot part. make a copy and stop the machine so the paper is in the middle catch it before it goes into the hot part are the lines there? be careful the toner will not be fuse your hand will smear the toner, if the lines are there you need to replace the cleaning blade and maybe the drum and get the image unit that houses the drum might need to be cleaned.
if no lines then the fuser is putting the lines on the copy replace the upper and lower fuser rollers and cleaning roller next to the lower fuser roller.
try this site as star to get parts.
Minolta EP1083... | Answered on Feb 22, 2015
There are small sensor under the big glass that look at the size of the document to figure what size it is, well one is bad they look like little bug eye looking up at the glass. replace one or both, try below web site for rough cost if available
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first wire transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
web site for parts
try below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Well try the site below and order a drum cleaning blade and developer then once you have that get the service manual for this machine try this site Service manuals electronic components datasheets and equipment schematics...
for parts try this
Minolta EP1083... | Answered on Feb 21, 2015
Well the C0500 code is the code that is given when the fusing unit is bad (THE HOT PART) to reset that code need to go to the rear remove top rear cover and press the small black button on the control board lower left. The C0400 is Exposure Lamp the bright lite under the big glass. Might need to get a new one try web site below as for the C0500 if it comes back do not reset get Konica Minolta rep to look at the fuser unit. IT can catch on fire and that would ruin a perfectly good day. If parts required see the web site below for a start Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Minolta EP1083... | Answered on Feb 20, 2015
The bright light (Exposure Lamp)under the big glass is having time problems might need to replace it
to reset the code remove the upper rear panel with machine on you will see a circuit board on the board a small black switch lower left press to reset.
if the code comes back see above
try this they mite have it
Minolta EP1083... | Answered on Feb 19, 2015
explain the sign message
Minolta EP1083... | Answered on Feb 17, 2015
has the optics been cleaned all the mirrors below the big glass how about the drum and developer has it been replaced?
Minolta EP1083... | Answered on Feb 15, 2015
The bright light under the big glass is not working raise the doc feeder or the original cover and press the start button bright light should come on. if not replace the lamp and or the control board.
Minolta EP1083... | Answered on Feb 14, 2015
has the developer been replaced and the required F8 run along with the drum counter reset. Also was the F5 run and F3 all of these F# are run in service mode.
Minolta EP1083... | Answered on Feb 08, 2015
What about it sir/mam?
Minolta EP1083... | Answered on Feb 07, 2015
111 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
code maintenance
  • Office Equipment & Supplies
