20 Most Recent Conair HCT-426 Hair Trimmer Questions & Answers
suggested that you NOT try and fix yourself. Take to a repair center. If quite old then recycle
Conair HCT-426... • Answered on Jun 09, 2014
digram on how to replace my blade in my hair trimmer conair hc3180v
Conair HCT-426... • Answered on Feb 11, 2012
mcdevito75 here, Simply refer to the part just as you"ve described it.
Conair HCT-426... • Answered on Jul 02, 2010
I am not sure if this will work but have you tryed changing the fuse
Or taking it apart and puting it back together just the parts that are removable
Conair HCT-426... • Answered on Mar 03, 2010
The way a shaver cuts your hair is because there are smaller blades inside the head moving back and forth and causes friction...
Conair HCT-426... • Answered on Jan 17, 2010
place the short blade on the bottom over the oblong piece then place the larger blade on top and screw back together, if there is a piece of foam inside make sure that is under both the blades and around the oblong piece (refered to earlier) which is sticking out of the top of the unit
Conair HCT-426... • Answered on Aug 11, 2009
Take them off by unscrewing them and realign
unscrew the blades and replace with new ones, alternatively oil the blades that are already on the clipper each time it is used. You will be surprised at the amount of hair clogged up on the inner blade when you take them off
It soulds like the blades are too far back. There is an adjustmebt piece to the right or left of the blade that is about 1 1/2-2" long and it slides forward and backwards.
Ths will adjust the blade depth. It sounds like the blades may be set too far back to cut your hair, this has to bring the 2 blades together so you have much less free edge on one side, so what you do is slide ths blade by adjusting the handle and bring the blades to just where one side is slightly shorter than the other less than 1 cm. Then make sure the guard is off and slde the adjustment head is set and then try it agan. Unusually it is the problem if it does not cut or the blades have come loose. Hope that helps.
Conair HCT-426... • Answered on Jun 19, 2009
I have the same issue. No reaction on screen, no light, letters, numbers, nothing at all.
I’ve checked the feet and all attached ok. Doesn’t seem anyway to check being them without removing the back entirely (no doubt invalidating any guarantee of getting it fixed/replaced).
Tried the customer helpline but no longer taking calls due to COVID!!
Maybe CONair is a little by of a warning.l in the name!
Conair Health &... • Answered on Mar 11, 2021
f the ALCI turns off the power to your hair dryer turn it off and then unplug it. Then press the reset button and plug it back in Just plug the hair dryer back in press test, and the dryer should stop working. To get it working again unplug it and press the reset button. It could be that your hair dryer has stopped working and you need a new one.
Conair Health &... • Answered on Jan 29, 2021
springs are used to apply pressure to the moving blade so the spring would go on the back of the blade under the screws
Conair Health &... • Answered on Dec 28, 2019
pout this case directly to the manufacturer and you may get a warranty replacement set or a refund of the money they do not know if consumers do not complain about their product
Conair Health &... • Answered on Dec 09, 2019
The battery compartment is on the underside, between the display and the foot to its left. Turn the scale over, and the compartment will now be near the foot to your right. It's about 1" x 2" and slightly oval. IIRC, there was a sticker covering it when I bought mine. There's the word "OPEN" and an arrow pointing to your left. Just to make it interesting, move the little latch the OPPOSITE of the way the arrow points to unlatch it! Pull up an you're in. The battery goes in with the positive side up as you're looking at the upside-down scale. It's a CR2032 cell I think, should be easy to find at Walgreens or Radio Shack.
Conair Health &... • Answered on Nov 05, 2019
Conair HCT-426 Hair Trimmer Logo
26 questions posted
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Conair Health & Beauty
Most Popular Question
change blades conair hct 426 hair
  • Health & Beauty
