20 Most Recent
Cartier Tank Francaise Chronograph White Dial Stainless Steel Watch Questions & Answers
I need a little help. I have replaced the battery
From ParksideJ:
- click the top button to stop the second hand
- click the bottom button to reset the timer
- pull the crown out all the way
- twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
- when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Setting a cartier chronograph watch
again.
I bought a watch from the charity shop today it is marked on the back with cartier paris 925 plaque or g20m swiss 17050343 can any one tell me about it
I keep saying the same thing on this board; call Cartier and describe the watch to them, you could also take digital photos of it & email them. They are always going to be your best resource for vintage or any other type Cartier watches. You can Google their number. Having said that, your watch seems like it may be a REPLICA ( meaning, fake, I'm sorry) 'Cartier' Argent, which may be worth around $250. It is not a real Cartier. There's no way even a charity shop would sell an authentic Cartier for anything under $1,000. I am sorry to disappoint you, and if you don't feel you can count on my say-so, you are welcome to call Cartier & verify what I've said.
Is the men's diamond wedding ring real serial #0905524
A genuine Cartier ring will be stamped on the back with Cartier's logo, the jewelry's metal type (Au 750 or 750 for 18k gold or Pt 950 or 950 for platinum), the ring size in mm, and a unique serial number. The stamp should be evenly spaced and, of course, free of any spelling mistakes.
Best to you
How do I change the flint on my Cartier lighter?
I am not familiar with this particular lighter, however, changing flints isn't usually difficult. Could you post a photo of the underside of the lighter? Try turning the lighter upside down. There should be two sections moulded in the bottom of the lighter. One is the refill port you use to fill it with gas, the other will be the adjuster or mount for the flint. The flint holder is usually a Spring loaded tube with the flint mounted at the top end. Carefully unwind the screw or twist cap being careful the spring doesn't suddenly release. This should slide out letting the remains of the old flint fall out. You may need to GENTLY tap the lighter to knock out any dust left by the old flint. Insert the new flint, insert the retaining pin and screw it in until it is finger tight. Screw too tight and you could crush the new flint or damage the screw thread on the retaining pin.
How do i know a
The best way is to have a watchmaker remove the back of the watch. The counterfeits usually have a cheap movement inside and that can help determine if its real or not.
