20 Most Recent Homedics Commercial Garment Steamer PS 200 Homedics Questions & Answers
steamers are usually believed to be easier to use and less damaging to the fabric over time
Garment Steamers... | Answered on Jan 11, 2018
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Garment Steamers... | Answered on Jun 24, 2015
Not an answer, but a note to say this same thing has just happened with mine in Sydney. Its only three months old. I have contacted Deals Direct, and they don't have any repair options. They won't replace it becuase they model they have in stock is a newer one to the one I have, so a return seems to be the only option. Pity, because I loved this thing. It really made ironing easier.
Garment Steamers... | Answered on Apr 17, 2015
Homedics Commercial Garment Steamer PS 200 Homedics Logo
4 questions posted
Top Homedics Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Homedics Garment Steamer and Press Expert? Answer questions, earn points and help others
View Most Popular
  • Homedics Garment Steamers & Presses
Most Popular Question
steamer will steam little while reset
  • Garment Steamers & Presses
