20 Most Recent Panasonic Appliances Steam Iron with Spray Questions & Answers
I never saw an iron with a retractable cord . The cover would have to be large enough to accomodate the cord and the heat from the iron could melt the cord. Are you sure it supposed to work like that? If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Panasonic... • Answered on Sep 24, 2013
The measuring cup holds 1/4 cup. Fill with tap water and pour one full measure into the hole exposed by removal of handle. Then measure table salt into small hollow on handle. Next, pour two (2) full measures of salt into a second measuring cup full of water, and pour into Sisan. Never use more salt than will fill the measuring hollow in handle. Remember that should the steam cease, unplug and refill with two measures of tap water, but no more salt. Maintenance: Add one (1) teaspoon white vinegar to two measures of tap water, put it in the Sisan Steamer and let it run a few minutes. Then pour this out of the Steamer and rinse well to scale the inside. https://www.google.com/search?q=Sisan+steamer+manual ..
Garment Steamers... • Answered on Apr 20, 2021
You will have to buy a new Shark Euro Pro Steamer because there are no longer any replacement parts for the current one that you have Shark had stopped making replacement parts for the one that you have too. . You could try on Kijiji and Craigslist. or the Market place on Facebook.
Garment Steamers... • Answered on Feb 03, 2021
steamers are usually believed to be easier to use and less damaging to the fabric over time
Garment Steamers... • Answered on Jan 11, 2018
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Garment Steamers... • Answered on Jun 24, 2015
Not an answer, but a note to say this same thing has just happened with mine in Sydney. Its only three months old. I have contacted Deals Direct, and they don't have any repair options. They won't replace it becuase they model they have in stock is a newer one to the one I have, so a return seems to be the only option. Pity, because I loved this thing. It really made ironing easier.
Garment Steamers... • Answered on Apr 17, 2015
Panasonic Appliances Steam Iron with Spray Logo
1 questions posted
Top Panasonic Garment Steamers & Presses Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Panasonic Garment Steamer and Press Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Garment Steamers & Presses
Most Popular Question
inherited iron without manual
  • Garment Steamers & Presses
