20 Most Recent
Bulova 98R107 Diamond Collection MotherOfPearl Dial w/ 24 Diamonds Watch for Women Questions & Answers
Bulova stailess steel 16 Diamond
You can try a polishing cloth to see if this removes the discoloration, or very gently brush it with a toothbrush and mild soap ( very little water) if this does not help you will need to send the watch back to Bulova to their service center. 1-800-228-5682 is the Bulova service center phone number, call them for further instructions. Sometimes the discoloration is caused by certain chemicals found in lotions, soaps and cleaners. Hope this helps! thank you!
Bulova 98R107...
Answered
on Sep 22, 2011
How long should a bulova watch work ---my husband
I would expect the battery to last more like 3 years than three weeks.
Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery?
I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced.
Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
Bulova Diamond...
Answered
on Oct 17, 2017
Whats the value of bulova watch c9671206 ?
NEED MORE INFO. From that serial number, it might be one of the old tuning fork movement watches. If the date code is from M0 (1960) through N6 (1977) it likely is. If so, it has a collector's value. In any case, the exact model, type of movement, and year would be needed to come up with a value. The serial number is just not enough.
Bulova Diamond...
Answered
on Aug 06, 2014
Set time on mz berger aw 205 388 sport watch
I just got a M.Z. Berger AW206 366 so the setup should be identical.
The watch has four buttons total. I'll name then by their positions. Top Left (TL), Top Right (TR), Bottom Left (BL), and Bottom Right (BR).
(BL) is your mode switch. Press it once at a time to toggle between modes, (Time, Chronograph, and Alarm). From the Time mode press (BL) three times. This will put you back in time mode with the seconds flashing. Press (TR) to toggle seconds back to '00'. Press (BR) to toggle to the next setting point, and (TR) to advance it. Just keep pressing (BR) until all the settings points are the way you want them. Note: In time setting mode it only advances the setting forward when you press (TR). So when using it to change hours display for 12/24 hour display or daylight savings time you just have to keep advancing the hour until it shows up correct. There is no DST or 12/24 display toggle on this watch. You just have to change the hours display manually. To exit time setting just press (BL) once.
Bulova Watches
Answered
on Nov 12, 2018
