20 Most Recent Yamaha 40N/50N 40 and 50 HP Outboard Motor Service/Shop/Repair Questions & Answers
Where do you connect the 12 v battery power cable to the engine on a 4stroke 40 hp yamaha year 2005.
Yamaha 40N/50N... | Answered on Dec 26, 2018
Your fuel pump is connected to the block which experiences positive and negative pressure. As the piston moves up it sucks fuel and air into the block. As the piston moves down it builds up pressure in the block. This pressure is used to force the fuel air mixture into the inlet port of the cylinder. So what you think is exhaust pressure is a normal condition. Get a rebuild kit and rebuild your fuel pump.
Yamaha 40N/50N... | Answered on Oct 22, 2018
Are the controls for the 'fast idle' loose? Also--run some seafoam through the fuel system on a regular basis--one per month.
Yamaha 40N/50N... | Answered on Oct 02, 2017
This can have some reasons:
1 clogged carburettors. Too less fuel means a hard start.
2 Worn spark plugs
3 Loss of compression... On a 2-stroke, measuring compression is not an exact science. Have throttle wide open. No spark plugs, check compression on all cylinders. They should be all within 1bar from eachother...
Yamaha 40N/50N... | Answered on Sep 25, 2017
It's located on the port side of the engine, You'll see just before the spark plugs the exhaust cover. At the top a cap, held with 2 10mm head bolts. There is the thermostat.
But, most of time the impeller parts will stay stuck in the tube between pump and engine block...
Need to hook up YDS diagnostics and check for codes first. Second you need to hook up a fuel pressure gauge on the motor and make sure your keeping steady fuel pressure. Did you check the grommet on top of the high pressure pump for a split in the rubber?
Yamaha 40N/50N... | Answered on Aug 20, 2017
One cylinder may be starved for oil causing the noise your hearing.
Not enough information, but there are two things I didn't read about you checking. Make sure the fuel quick connection on the engine (and possibly the fuel tank) is locked all the way in first, Then see if your fuel pump is working. Disconnect the fuel line from the carb and, holding it in a gas can, have someone turn on the ignition. If It's an electric pump, it should start running fuel, if mechanical, they'll have to crank it a little to get fuel going. If you get plenty of fuel that way, your float in the carb could have gotten stuck, or something in the line got into it.
Yamaha 40N/50N... | Answered on Mar 26, 2017
Yamaha 40N/50N 40 and 50 HP Outboard Motor Service/Shop/Repair Logo
42 questions posted
Top Yamaha Boating Experts
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Vincent G
Vincent G
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Boating
  • Yamaha Boating
Most Popular Question
2009 yamaha f150 4 stroke runs good
  • Boating
