20 Most Recent Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer Questions & Answers
Start at the transducer, mount it then pull the transducer wiring forward using a wire snake. At the same time pull forward 14ga wire to attach to your power leads.
on most boats I've done this process takes from 90 minutes to 3 hours.
The transducer and head unit are easy to put on. Getting wire from point A to point B is the time consuming part.
Once you have your wires pulled forward route them to your head unit at your console. Drilling of access holes may be required.
Connect power, plug in the transducer line.
Black to negative at the battery, red to positive, don't forget to put in the in line fuse included in your box.
Good luck.
Lowrance Elite-7... | Answered on May 27, 2015
Since you just purchased it contact the seller, it should be covered under warranty.
Lowrance Elite-7... | Answered on Mar 02, 2015
Assuming you are using Navionics, plug your charts memory into your computer log into Navionics and follow the prompts for update
Lowrance Elite-7... | Answered on Nov 26, 2014
Hi Kane,
I have this manual for you on how to set up setting up Language on page 42 to 43. Hope it helps.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-7_HDI_OM_EN_988-10423-001_w.pdf
Lowrance Elite-7... | Answered on Apr 25, 2014
Go into your settkngs function. Change the view from North up to heading up.
Lowrance Elite-7... | Answered on Jan 11, 2014
A transducer does not give "colors".. the unit its plugged into provides the colors..
50khz for deep water.. 200khz for shallow water..
A transducer simply sends and receives signals to and from whatever is on the bottom of the lake...
Lowrance Boating | Answered on Dec 15, 2019
For deep water you will want to run the lowest hertz setting. For example, if you have the option for 80hZ or 600hZ, then the 80hZ would be for deep water and the 600hZ would be for shallow water.
Lowrance Boating | Answered on Oct 03, 2019
Reset use a soft reboot. Or hard reset make sure you back up all your settings on fish finder with chip or home computer. OK guys so the first thing you wanna do when resetting your unit whether it's soft reset or hard reset we're gonna start with a soft reset which is gonna save any GPS data anything like that so we're gonna head over hold the Power & Page button press the power button we're going to go over and press power button but I'm at the unit but up until you see the warning screen where you have to except the depth on reset Can see we still have our Saved waypoints. OK now I'm gonna show you how to do a hard reset again turn the unit off you should always use the power key never just flip the main power switch to off then press and hold the plus minus key as well as the power key let go of the power key keep holding plus minus until the warning screen comes up in a hard reset your going to delete all data on this year it's gonna be like we just bought it went to the store and bought it and cam home with know data whatsoever no settings nothing OK I warning screen has came up we can let go of her buttons and press except start demo. OK now I'm gonna show you how to do a hard reset again turn the unit off you should always use the power key never just flip the main power so that our unit is off then press and hold the plus & minus key as well as the power key don't let go with the power key holder plus minus until the warning screen comes up and a hard reset is going to delete all data on this year it's gonna be like-you just bought it went to the store and bought it and brought it home no data whatsoever no settings nothing OK or warning screen has came up we can let go over buttons and press except start demo now. OK so now you should not see any saved data so that's how you do a hard reset and a self reset. Load your Data card and shut off the power key. Then turn back on and follow screen steps. This should fix you issues.
Walld"
Lowrance Boating | Answered on Oct 02, 2019
Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer Logo
20 questions posted
Top Lowrance Boating Experts
Mike
Marvin
Marvin
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
View Most Popular
Lowrance Boating
  • Lowrance Boating
Most Popular Question
navigate back waypoint
  • Boating
