20 Most Recent Uniden Guardian Wireless Video Surveillance System Questions & Answers
5answers
Record File Error on Guardian 2
I was getting the same trouble with the "record file error" always showing up on my monitor as well, and no recordings were being written into the SD card. I tried different SD cards and the same message was appearing. I was about to pack it up and return it to the store until I did one last thing...and it worked for me! Solution: Using a paper clip, insert the end of it into the "reset" hole under the SD slot and the system will turn off, restart, and voila!...it will start recording again. I hope this helps everyone who has this similar problem out there. I guess the unit just need a good reboot and get some of the bugs out of it's system.
10/22/2019 10:46:02 PM • Uniden Guardian... • Answered on Oct 22, 2019
0answers
0answers
Unit doesn't turn on by pushing power button
Check the power supply make sure it's connected properly then if plugged to an outlet you know works and it still has no power then I'd say the power supply is bad
3/1/2014 11:27:50 PM • Uniden Guardian... • Answered on Mar 01, 2014
Cannot remotely view the cameras error -6
We'll call your neighbor if u had an power outage then your system has rebooted and kick the wifi into default wich u cannot remotely view your home
3/1/2014 4:46:42 PM • Uniden Guardian... • Answered on Mar 01, 2014
0answers
Free driver for UDW10055 uniden surveillance camera
http://my.uniden.com/downloads.cfm?product=UDW20055 The above link is for UDW20055. Might work???
11/23/2019 11:28:29 PM • Uniden Home... • Answered on Nov 23, 2019
I have a UWS 1101 Uniden surveillance system, the registration code and registration name are not legible anymore and I need to set it up again, how can I get the codes?
You might not be able to do it. There is a very small chance that there is another label inside the unit but you'd have to take off a cover in order to find out. You can also try taking a picture of the label at different angles and under different lighting conditions. Sometimes you can read the information by zooming in on the digital picture and adjusting the contrast or white balance, or even converting it to a negative sometimes works to bring out the faded information... This method unfortunately doesn't work well on foil labels where there is shiny foil showing through the label.
12/21/2018 12:25:31 AM • Uniden Home... • Answered on Dec 21, 2018
Looking for pairing pigtail for uniden GC45 camera
As this is a discontinued product, your best option for obtaining a pigtail is probably going to be to buy a used camera from someplace like eBay...
12/21/2018 12:13:01 AM • Uniden Home... • Answered on Dec 21, 2018
Where do I find the uid number for a Uniden G1420 surveillance system
This UID code can be found on the back of your handheld monitor behind the kickstand or mount. It is the characters underneath the barcode. You also can find the UID code on the Network Information screen.
12/21/2018 12:04:31 AM • Uniden Home... • Answered on Dec 21, 2018
Can I hardwire a G14 Uniden camera
playerunknowns battlegrounds cd key, buy playerunknowns battlegrounds cd key, buy playerunknowns battlegrounds code, pubg cdkey, pubg keys https://www.m8x.com/cdkeys/playerunknowns-battlegrounds-pubg.html
12/13/2018 5:40:06 AM • Uniden Home... • Answered on Dec 13, 2018
I have the uniden home security camera and I can hook up to 4 cameras I just finally put up number 2 and now it keeps shutting off why?? also how do I down load to phone so I can see remotely
notify uniden support for help and instructional information they will need the make and model info
6/16/2018 12:03:05 PM • Uniden Home... • Answered on Jun 16, 2018
What uniden wireless cameras will work with a udw20553 system
Considering this unit is nearly 8 years old, you would be hard-pressed to find compatible wireless cameras. UDWC25 and UNDGC45 cameras are compatible. Neither is made any longer.
11/22/2017 8:06:41 AM • Uniden Home... • Answered on Nov 22, 2017
Uniden Guardian Wireless Video Surveillance System Logo
8 questions posted
Top Uniden Home Security Experts
john h
ADMIN Andrew
ADMIN Andrew
MegaByteMe
MegaByteMe
Are you an Uniden Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Uniden Home Security
Most Popular Question
record file error guardian 2
  • Home Security
