20 Most Recent GE WWSE6260B Top Load Washer Questions & Answers
manual
Agitator not workng right lights flicker
The washing machine is probably not at fault for this. If it really were to have a problem of drawing excessive power, it would trip a breaker, and you didn't indicate any such problem. You probably should consult with a qualified electrician to find the problem with your electric service or house wiring.
2/2/2011 3:10:48 AM • GE WWSE6260B Top... • Answered on Feb 02, 2011
Loud knocking three separate times during cycle
Friend,
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to the drive of the agitator is worn and needs to be replaced.Similar to tyhe drive shaft of a rear wheel drive v-8 car!
Could sound like a knock,knock,knock or klack, klack,klack
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
8/31/2008 1:15:06 AM • GE WWSE6260B Top... • Answered on Aug 31, 2008
WWSE3160A0AA waching machine turns on the light
replace the control board behind the panel. depending on the age of machine. you may just have to replace the machine.
8/17/2008 8:53:01 PM • GE WWSE6260B Top... • Answered on Aug 17, 2008
Can I get new brushes for my GE handmixer 56M17
No there’s no brushes for GE handmixer
3/10/2024 8:12:40 PM • GE Washing... • Answered on Mar 10, 2024
GE WSLP1100A0WW not agitating
It sounds like the clutch is slipping https://www.google.com/search?q=GE+WSLP1100A0WW+not+agitating
Top Load Washer - Fills But Will Not Agitate
GE Appliances https://products.geappliances.com > appliance > gea-sup... If the lid switch probe or magnet is missing or damaged, the washer will not agitate or spin, even with the lid closed. Missing: WSLP1100A0WW ‎' Show results with: WSLP1100A0WW
SOLVED: GE WSLP1100A0WW not agitating
Fixya https://www.fixya.com > ... > Washing Machines > GE 17 hours ago - Ge top loader washer agitator does not work To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator.
Ge Washing Machine - Washer Won't Spin Or Agitate
Repair Clinic https://www.repairclinic.com > RepairHelp > Ge-Washe... If a washer is not spinning or agitating, you should first determine if the drive motor is running and if power is reaching the drive motor. If no power if ... ..
3/5/2024 1:09:38 AM • GE Washing... • Answered on Mar 05, 2024
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather Good to see you again. Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely. One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe. ..
2/23/2024 8:08:04 PM • GE Washing... • Answered on Feb 23, 2024
2answers
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
12/11/2023 6:33:13 PM • GE Washing... • Answered on Dec 11, 2023
2answers
GE Washing Machine model GTW330ASK0WW. It won't run, no sounds, display comes on and after 15 seconds shuts down.
Question edited for clarity 'MAKE model (WHAT IT IS)'. You posted to Televisions, moved to GE Washing Machine. It may be the lid lock, test it with your digital multimeter. Look for loose or damaged connections. https://www.google.com/search?q=GE+Gtw330ask0ww+not+running ..
10/21/2023 3:04:17 AM • GE Washing... • Answered on Oct 21, 2023
2answers
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation.
check under agitator possible worn cogs
10/21/2023 3:02:47 AM • GE Washing... • Answered on Oct 21, 2023
2answers
Why wont My ge washer drain
check voltage to pump if ok bad pump also check drain hose
10/21/2023 2:59:12 AM • GE Washing... • Answered on Oct 21, 2023
Ge washer h20 supply error
Check the water level sensor.
10/12/2023 7:52:46 AM • GE Washing... • Answered on Oct 12, 2023
Winterizing a washer in a summer cabin
Just remove the drain hose from the drain upstand pipe and lower it to the floor. It will empty the pump or water.You can also drop a pint of car anti freeze into the machine just to be sure if you wish.
10/10/2023 5:24:57 AM • GE Washing... • Answered on Oct 10, 2023
Why is my GE front load washer breaking the circuit after it starts to fill with water?
You likely have a water leak spraying onto electrics, or the water inlet valve is shorting out.
10/1/2023 3:42:48 AM • GE Washing... • Answered on Oct 01, 2023
Top Loader GE with impeller not agitator leaving oily looking stains
Remove the bottom impeller and clean out the water proof grease that has come out of the seal and drive shaft.
9/27/2023 5:16:31 PM • GE Washing... • Answered on Sep 27, 2023
How to reset a GE washing machine WPDH8900J1WW
I understand your frustration. It sounds like your GE washing machine is having some problems. Resetting the washer may help to fix the issue. Here are the steps on how to reset a GE washing machine WPDH8900J1WW: 1. Unplug the washer from the power outlet. 2. Wait for 2 minutes. 3. Plug the washer back in. 4. Turn on the washer. 5. Select a cycle and press the start button. If the washer still does not work, you can try resetting the drum motor. To do this, follow these steps: 1. Unplug the washer from the power outlet. 2. Wait for 1 minute. 3. Plug the washer back in. 4. Open and close the lid of the washer 6 times within 12 seconds. 5. Close the lid and press the start button. If the washer still does not work after resetting the drum motor, you may need to contact a qualified appliance repair technician. Here are some other things you can try before resetting the washer: * Make sure that the washer is properly leveled. * Check the water supply hoses for leaks. * Clean the lint trap. * Check the detergent dispenser for clogs. I hope this helps!
8/27/2023 8:59:56 PM • GE Washing... • Answered on Aug 27, 2023
How to get into service mode on my GE GFWN1600?
Please see the following link for the error codes https://www.youtube.com/watch?v=JglsX87UdeY&pp=ygUvSG93IHRvIGdldCBpbnRvIHNlcnZpY2UgbW9kZSBvbiBteSBHRSBHRldOMTYwMD8%3D
8/27/2023 1:11:33 PM • GE Washing... • Answered on Aug 27, 2023
My GE top load washer model 110.27062603 will not run through a full cycle. Sometimes it washes, but 17 minutes showing, jumps to 2 minutes, then shuts off with 'OL' error code.
OL = Overloaded. Is the Washer overloaded? If OL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent.Feb 24, 2020
OL - Error Code - Top Load Washer - Product Help - Maytag
Maytag https://producthelp.maytag.com > ... > OL
The washer has ol on it at the end - Maytag Bravos quiet ...
iFixit https://www.ifixit.com > Answers > View > The+washe... Oct 6, 2014 · 2 answers First, OL stands for "Overload", so in other words, the washer thinks the tub is too hard to move because it's overloaded and the motor is ... OL code all the time even with very small and light ... 2 answers Sep 28, 2016 Why washer stops and gives code "ol" - iFixit 2 answers Nov 30, 2016 at the end it says OL - Maytag Bravos quiet series 300 ... 1 answer Dec 29, 2022 OL code showing . - Kenmore 110 Series Washing ... 2 answers Sep 19, 2017 More results from www.ifixit.com
7/14/2023 12:07:29 AM • GE Washing... • Answered on Jul 14, 2023
GE WWSE6260B Top Load Washer Logo
Popular Tags
14 questions posted
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
loud knocking three separate times
  • Washing Machines
