20 Most Recent GE Profile Prodigy DPSR513GA Dryer Questions & Answers
sounds like one of the keys in the tumbler is broken maybe
GE Profile... | Answered on Feb 09, 2015
You need to take the front off the dryer and it will be alongside the gas tube going inside the combustion chamber. The igniter is one of those curly wand types and has a quick disconnect connector on it and is secured with a couple of screws.
Here are some diagrams that might help you:
GE Gas Dryer Parts Model DPSR513GA
Good luck.
GE Profile... | Answered on Oct 19, 2014
the pilot your seeing is the ignitor the gas valve coils are probably bad these are mounted on top of the gas supply valve on the burner tube,you need to unplug the unit and remove the top and front cover to access the valve and coils,there are 2 screws securing the gas coil valves onto the gas valve remove these and remove the bracket,unplug the coils and reverse to re assemble the unit
GE Profile... | Answered on Feb 23, 2013
sounds like heater element or heat sensor
GE Profile... | Answered on Jan 31, 2012
Our laundry room is in the center of the house and the dryer vent runs underneath the house and every 6 months or so we have to run a plumbing snake all the way through the vent pipe. Once it all the way through the house we then tie a rope to the end of it with a huge knot tied into it, we then snake the rope through the pipe and it pulls out all the lint that has collected inside, someone at each end of the rope (make sure it's long enough) and run it back and forth until no more lint is collected. I hope this might help you.
GE Profile... | Answered on Apr 15, 2011
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
GE Profile... | Answered on Apr 12, 2011
That could be the problem look at how the belt is running thru the tensioner and the shaft of the motor. Then run the belt the opposite way if still the same you might have the wrong belt. Get the model number off the dryer and take new belt back to parts house with model number to make sure its right hope this helps.
GE Profile... | Answered on Jan 07, 2011
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
GE Profile... | Answered on Nov 15, 2010
timer motor sounds like, here is how to test:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
GE Profile... | Answered on Nov 11, 2010
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
GE Profile... | Answered on Oct 28, 2010
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fghgs
GE Profile... | Answered on Sep 29, 2010
heatman101
sfhgf
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
GE Profile... | Answered on Sep 21, 2010
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
GE Profile... | Answered on Sep 03, 2010
Dryers Logo
58 questions posted
Top GE Dryers Experts
gbob59
Marvin
Marvin
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
dryer heating
  • Dryers
