20 Most Recent
Canon imageRUNNER 2800 Black and White Copier Questions & Answers
Copier is not working it receiving code E0064
these means that you have problems with high voltage.
Maybe the power grid or high voltage pcb.
By the way did you play with the bias? If yes return it to previous state.
Hope that helps!
3/23/2012 5:53:16 AM •
Canon...
Answered
on Mar 23, 2012
TONER WASTE CONTAINER FULL EMPTI3ED CONTAINER HOW
When you empied out the waste toner bottle you have to make sure the neck of the bottle is cleaned very well.... The two circles on the neck need to be cleaned. There is a sensor that looks throught those two spots. The only thing you need to do is to turn the main power switch "OFF" then back "ON" .... Good Luck
4/21/2011 2:09:48 AM •
Canon...
Answered
on Apr 21, 2011
Won't print;
The problem means that your hard disk needs to be replaced. E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed. Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the hdd from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
Thank you !!
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the hdd and it will pup up ready to go.
Hope this helps.....
5/21/2010 2:41:26 PM •
Canon...
Answered
on May 21, 2010
How do i remove the fuser unit?
Firstly, you have to take off the left hand door by opening the lower door and removing the metal wire retainer that is hooked over the machine chassis. Once the door is off, you will see a black plastic cover just above where you removed the retainer from. One screw removes that to expose the connectors for the fuser. There is a black plastic guide that runs the length of the fuserone screw removes that - be sure to note the way this guide fits under the roller shaft for reassembly. Once this is removed you will see the two screws that hold in the fuser remove them and the fuser slides out at an angle, i think you pull towards you first, the side towards the front of the machine. If it feels stiff then you've got the green latch in the front of the machine in the wrong position, turn it the other way. You need the front door open for all of this. Good luck.
7/9/2009 6:45:34 PM •
Canon...
Answered
on Jul 09, 2009
I emptied the waste toner recepticle on the canon
Yes, when you emptied the waste toner bottle - you should have cleaned the neck of the bottle because if there is toner stuck to it(which there usually is) the machinestill thinks it's full because an optical sensor reads the level through this neck - through a circular inset that you'll notice upon inspection. Just clean the bottle neck.
7/8/2009 8:42:48 PM •
Canon...
Answered
on Jul 08, 2009
Scanner canon dr6030 cants pull the paper
Troubleshoot this issue step by step:
Check the Feed Selection Lever:
Ensure that the Feed Selection Lever (located on the lower left side of the front of the scanner) is in the correct position (up) for separation.
Straighten the edges of the stack of documents to be scanned.
Set the document guides so they are wider than the document to be scanned.
Place the documents face up into the feed tray, ensuring they touch the document stoppers.
Clear Any Jammed Paper:
Be careful when removing jammed paper to avoid cuts.
Remove any documents that have been left in the eject tray.
Close the document eject tray.
If the document ejection is stopped partway, perform this operation with the document eject tray extension open.
Hold the upper unit as shown in the diagram and open it to the point where you can remove the jammed document. The pickup roller is located in the middle of the upper unit. Do not hold the protrusion on the upper unit when opening it, as it may deform the pickup roller or cause a feeding error.
Close the feeder cover.
If the jam occurred in the feed section, pull the document out carefully without applying too much force. Be sure to remove any torn parts remaining in the scanner.
Close the upper unit slowly, ensuring it clicks into place. Do not force it to close, as this may damage the scanner.
After removing the jammed paper, check if the last page was scanned, and then continue scanning.
Rapid Recover System:
If a paper jam occurs when the "Rapid Recover System" is enabled in the ISIS/TWAIN driver settings, the image of the document is not saved, and scanning stops. You can continue scanning from the document that caused the paper jam after fixing the issue.
Additional Considerations:
Make sure the pickup rollers retract when the machine is powered on.
Check that the stopper plates are in the down position.
Verify that the upper unit is completely closed after clearing the jam.
Remember to handle the scanner components carefully to avoid damage. If the issue persists, consider seeking professional assistance or contacting Canon support for further guidance
I have a problem with my canon printer g3411. It has an error P03 but no paper jam. How do I solve my problem
Error P03 on a Canon printer typically indicates a paper jam, even if you cannot physically see any jammed paper. Here are a few steps you can try to resolve the issue:
- Turn off the printer and unplug it from the power source.
- Carefully check the paper tray and inside the printer for any jammed paper or debris.
- Remove any jammed paper or debris you find.
- Plug the printer back in and turn it on.
- Attempt to print again.
If you don't see any paper jammed in the printer, there are a few other things you can try to resolve the error P03:
- Try resetting the printer. To do this, turn off the printer, unplug it from the power source, and wait for a few minutes before plugging it back in and turning it on.
- Check the ink cartridges and make sure they are properly seated and have enough ink.
- Clean the printer's rollers. Rollers are the small rubber wheels inside the printer that move the paper through the printer. Over time, dust, debris, or ink can build up on the rollers and cause paper jams. Cleaning the rollers can help resolve the issue.
- Try to update the firmware of the printer. Sometimes, a firmware update can resolve the issue.
- Check the printer's settings, ensure that the size of paper loaded match the size of paper set in the settings.
If the problem persists after trying these steps, you may want to contact Canon support for further assistance.
How to slove error e732-001 of canon ir 3225
The E732-001 error on a Canon iR 3225 indicates an issue with the fixing assembly temperature. Here are some steps to troubleshoot and resolve this error:
Reset the Condition:
Enter service mode by pressing the following sequence on the control panel: COPIER > FUNCTION > CLEAR > ERR.
This will reset the error condition. If the message disappears, your printer is ready to use. If this doesn't work, there may be a hardware problem as addressed below.
Replace the Main Thermistor:
The main thermistor is responsible for temperature sensing. If it's faulty, it can trigger the E732-001 error.
Consider replacing the main thermistor to resolve the issue.
Check the DC Controller PCB:
If the problem persists, inspect the DC controller PCB for any defects or malfunctions.
Replacing the DC controller PCB may be necessary.
Remember to turn off the printer before performing any maintenance tasks. If the error persists or if you need further assistance, I recommend contacting your local authorized Canon dealer or the Canon Customer Support Center for professional service
