20 Most Recent Ricoh Aficio MP 1600 Black and White Copier Questions & Answers
Buondi' la macchina non riconosce il formato a4 in fase di stampa
mi dice sempre di mettere la carta nel by pass cosa posso fare?
grazie
Ricoh Aficio MP... | Answered on Jul 09, 2014
reset with sp code 5-810
Ricoh Aficio MP... | Answered on May 27, 2014
If it is not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/harper/hopper.
Ricoh Aficio MP... | Answered on May 05, 2014
If copier is saying to replace it. Will need to by a photoconductor unit then open right side door then open front door pull toner assy out ward and on photo unit front bottom press on latch each side and pull it out to remove it. There might be instruction after putting new one in to run a initialize code
Ricoh Aficio MP... | Answered on Jan 23, 2014
SC990 means that the hard drive has failed..... It needs to be replaced with a new one or a hard drive from another copier of the same model. Or you can disconnect the finisher.
Ricoh Aficio MP... | Answered on Jan 13, 2014
The problem can be solved exactly from the maintenance manual download here:
http://support.ricoh.com/bb_v1oi/pub_e/oi/0001026/0001026506/VG1398504/G1398504.pdf
Ricoh Aficio MP... | Answered on Jan 08, 2014
what problem does it gives when photocopy machine get under light.it that true it give dark on the top of the paper
it is the password we don't share, my apple ID is
[email protected]
Ricoh Aficio MP... | Answered on Oct 26, 2013
this is a charge issue - a simple fix would be to remove the pcu and clean round its outside and then clean the contacts to it inside the machine - if this doesnt work the pcu needs stripping down
Ricoh Aficio MP... | Answered on Oct 22, 2013
Here is the answer to your question:
http://www.tradebit.com/filedetail.php/225822562-ricoh-mp1500-aficio-mp1600-mp2000-l-service
Ricoh Aficio MP... | Answered on Jun 20, 2013
You need a service manual to diagnose this problem. Here is a link to cheap manual for your equipment.
Fusing thermistor open (rear)
Ricoh Aficio MP... | Answered on May 29, 2013
Ricoh Aficio MP 1600 Black and White Copier Logo
60 questions posted
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
change drum
  • Office Equipment & Supplies
