20 Most Recent Ricoh Aficio MP 161 Black and White Copier Questions & Answers
4answers
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
2/14/2019 10:43:14 AM • Ricoh Aficio MP... • Answered on Feb 14, 2019
Aficio MP161 Toner bottle doesn't turn to add toner.
How many copies on that machine? The photoconductor unit on that model only goes 45,000 copies. If the machine wont tone up and the pcu is old i would replace it and calibrate to see if the problem goes away. The pcu is cheap for that model. Start there would be my advice.
6/7/2017 3:32:14 AM • Ricoh Aficio MP... • Answered on Jun 07, 2017
Sc:829 code:301 detail:A4000001
there is something wrong in that machine this making it display this error code. The error code has a meaning and this meaning needs to be interpreted first, before the problem can be identified.
The error code means; charge Corona problem. The charge Corona of your machine is defective and that's what causing the problem. The charge corona is a power pack and it is located inside the drum of the machine.
To be frank, you will need
a technician to help you service the machine in other to get it fixed.
Good luck.
5/16/2017 9:20:38 PM • Ricoh Aficio MP... • Answered on May 16, 2017
Mp161 prints half page
This problem is usualy related to the laser unit/Polygon mirror motor. Ask your local technician to replace the polygon mirror motor, this part is normally cheap.
7/14/2015 12:37:09 PM • Ricoh Aficio MP... • Answered on Jul 14, 2015
How to enter service mode in ricoh aficio mp 161
Service mode is 'Clear-1-0-7-stop (hold stop until machine goes into service mode).
9/19/2014 9:32:55 AM • Ricoh Aficio MP... • Answered on Sep 19, 2014
0answers
0answers
Reset drum count
You want SP7-992-4 (Counter Reset).
3/15/2014 7:57:47 AM • Ricoh Aficio MP... • Answered on Mar 15, 2014
Mp 161
open the right cover where you normally remove the paper jams,then open front cover/door where you put toner,lift the green handle up,push green lock towards the right side while pulling the hopper out,then theres a connector beneath the PCU,pull it then pull out the PCU,use the same same procedure to put it in,start with the PCU,return the connector and put in the hopper,then close all doors/covers
3/7/2014 11:43:17 AM • Ricoh Aficio MP... • Answered on Mar 07, 2014
Error code sc542
Fusing Temperature Warming-up Error • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermofuse open • BCU defective • AC drive board defective • Poor fusing unit connection
1/21/2014 2:40:17 AM • Ricoh Aficio MP... • Answered on Jan 21, 2014
The switch above te paper tray. How much is it.It
the price is around : 30 euros part number : B044 5300 Paper End Sensor
12/8/2013 1:37:10 AM • Ricoh Aficio MP... • Answered on Dec 08, 2013
0answers
Ricoh 161
Be the first to answer 11/7/2013 11:55:29 PM • Ricoh Aficio MP... • Posted on Nov 07, 2013Be the first to answer
0answers
Reset error code
replace laser unit
5/11/2013 9:20:35 PM • Ricoh Aficio MP... • Answered on May 11, 2013
Ricoh Aficio MP 161 Black and White Copier Logo
103 questions posted
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
reset mp161 ricio
  • Office Equipment & Supplies
