20 Most Recent Canon imageCLASS D480 Black and White Copier Questions & Answers
I have a cannon image class d480 when I print a document only 1 page gets printed followed by a blank page. A red error light flashes at the processing data sign.
Try going into Control Panel > Printers and Properties, right-click on your printer icon and go into Printer Preferences for that printer. Make sure both Page Size and Output Size are set for the the same size of what you are printing (Letter, Letter/Legal, Legal/A4,A4, etc). Often, Output size is set to Match Page Size...that was causing the problem for me.
11/27/2021 6:49:13 PM • Canon imageCLASS... • Answered on Nov 27, 2021
D480 processing light and error light stay on
Hello, is there an error code on your display?
11/4/2019 6:51:12 AM • Canon imageCLASS... • Answered on Nov 04, 2019
How do I clean the drum in a Canon 104 toner cartridge
How about just replace it..... You really can not service the cartridge, they make it that way..... Sorry, Good Luck
2/6/2013 1:58:49 AM • Canon imageCLASS... • Answered on Feb 06, 2013
The scanner function on my Canon D480 has not worked since the installation.
Go to the scanner company website and see if there are drivers available for download. Sounds as if you may not have the proper drivers installed.
1/8/2013 6:43:34 AM • Canon imageCLASS... • Answered on Jan 08, 2013
I have black lines on my scans & copies, but
simply take a moist cloth and clean the strip glass .the dust on the strip glass is causing the lines.u might have to remove the flatbed glass to access the inside of the strip glass.
8/20/2011 3:58:41 PM • Canon imageCLASS... • Answered on Aug 20, 2011
Cannon imageCLASS D480....will not work
it is related to CIS unit and SCNT Board. check it. if it is demage you require to replace it.
4/27/2011 4:30:22 AM • Canon imageCLASS... • Answered on Apr 27, 2011
I get a black line
You have to clean the small piece of glass that is right under the adf paper path...... Good Luck... The mark or dirt is on that glass..... Follow the paper path of the paper when it goes through the adf
4/17/2011 12:55:15 AM • Canon imageCLASS... • Answered on Apr 17, 2011
Canon D480 document feeder doesn't always feed
First, try changing some Document Feed Rollers etc.
FC8-9251-000 is the pickup roller
FL3-1023-000 is the separation pad
FM3-8679-000 is the feed roller
That would fix 80% of the problems you may encounter
Whit
Item, Inc.
4/6/2011 3:27:16 PM • Canon imageCLASS... • Answered on Apr 06, 2011
Where can i find a software for this printer
http://software.canon-europe.com/
8/20/2010 7:50:21 AM • Canon imageCLASS... • Answered on Aug 20, 2010
Where do I find Baud 9600 Rate and ECM?
You can't, plus it will not help on a digital phone system. ALL fax machines are ANALOG devices.
6/29/2010 10:17:32 PM • Canon imageCLASS... • Answered on Jun 29, 2010
I cannot seem to clear "paperjam" message even
there is a real possiblity that one of the sensor flags for feeding the paper has gotten stuck or has broken off which is not setting off the sensor for the paper jam. Or there is a very small piece of paper stuck in the sensor that is keeping it from clearing,
6/11/2010 5:34:54 AM • Canon imageCLASS... • Answered on Jun 11, 2010
Why do I have a black line on my copies?
Pull out the toner crg., and if there are streaks on the drum, replace crg. If there is no streaks on the drum, clean the copy glasses.
6/2/2010 9:47:40 AM • Canon imageCLASS... • Answered on Jun 02, 2010
Paper jam message does not clear after paper jam
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your copier
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the copier
5. Close all doors and put back all trays
6. Turn on your copier
NOTE: Please rate our help to keep this free service online.
1/12/2010 2:45:05 AM • Canon imageCLASS... • Answered on Jan 12, 2010
Canon imageCLASS D480 Black and White Copier Logo
41 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
clean drum in canon 104 toner cartridge
  • Office Equipment & Supplies
