20 Most Recent
Hitachi CP-RS55 LCD Projector Questions & Answers
Why won't our projector power on?
The power indicator is off.
two reason:
1,the mainboard is fault
2,the powersupply is fault
I Supply the Projector accessories,in China.
projector accessories:Laser Diode Module,lamp,bulb,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast...with high quality and competitive price.
WhatsApp ID:+8613178867858
Skype:
[email protected]
Wechat ID:+8613178867858
Email:
[email protected]
Email:
[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
I work in a school
Your Blue LCD Light valve is burned or has dust on it which blocks the blue color.With RGB, the absense of blue (Red + Green) is yellow.If you're lucky a simply cleaning at the light valves will solve your problem. Otherwise your looking $$ for a new LCD valve.
I want transistor Q103 value smps please
The service manual doesnt show what the transistor type is. It's an npn high voltage low power switching transistor. does it have anything printed on the body ie Cxxxx where xxxx are 4 numbers
Loss of good colour constant blue ghosting to
This will require a technician to repair.
You can do it yourself if you have the service manual and some knowledge of electronic repair, and access to the necessary parts.
It's generally cheaper to buy a new unit than to have one repaired though, unless of course it's under warranty.
Re set timer?
hi,
To reset the lamp hour timer do the following,
1. Power on the projector
2. press the menu button
3. Select option
4. in the option menu select Lamp time
5 press and hold the reset button on the remote or Right arrow button on the projector for 3 seconds
the lamp reset diagonal box will appear
6 using the up arrow button select reset.
Also try to reset the filter time using the same procedure
lamp reset is recommended only after the lamp replacement.
ok
Check air flow
Unclip the air filter covers and remove the filters, making sure not to let the dust stray into the machine.
Clean the filters. Depending on the type of filter, either wash them in mild washing up detergent or replace them if they are the paper element type.
That is all one can do without stripping the machine down and clean the vanes on the fans.
MESin basuh Hitachi sf-105s saya tidak bisa hidup.saya sudah menukar pcb board control dengan yang baru..tapi mesin masih tidak boleh hidup
Jika mesin basuh Hitachi SF-105S Anda masih tidak dapat menyala setelah Anda mengganti pcb board control yang baru, maka ada kemungkinan bahwa masalahnya terletak pada pcb power board atau bagian lain dari mesin. Untuk menentukan apa yang perlu diganti, ada beberapa langkah yang dapat Anda lakukan:
- Periksa kabel daya dan sambungannya untuk memastikan tidak ada kerusakan atau kelonggaran.
- Periksa bagian lain dari mesin, seperti switch atau saklar, untuk memastikan tidak ada yang rusak atau tidak berfungsi dengan baik.
- Periksa pcb power board untuk mencari tanda-tanda kerusakan, seperti komponen yang terbakar atau terkelupas.
The temp light on my Hitachi projector is constantly red. what does this mean?
Hi Sam, the temperature light, tells you that the ventilation system is not working properly
As a first step, remove the filter (s) and clean them well or replace them with new filters.
It would also be important to do an interior cleaning, do not use torches or air sprays, since they can do more damage than solution, always try to vacuum dirt
I hope you can make your Hitachi work properly
Regards Franco Dosil
Hola Sam, la luz de temperatura, te indica que el sistema de ventilacion no esta trabajando correctamente
Como primera medida , saca el o los filtros y limpialos bien o reemplazalos por filtros nuevos
Tambien seria importante hacer una limpieza interior, no utilices ni sopletes ni aerosoles de aire, ya que pueden hacer mas da?o que solucion, siempre trata de aspirar la suciedad
espero Puedas hacer funcionar correctamente tu Hitachi
Saludos Franco Dosil
Hi, my Hitachi CP-X445 projector will not stay running for more than 5 minutes when mounted feet up, but there is no problem running feet down, any ideas?shuts down on high temp
Thanks, Jose
the lamp is not good
you need a Original lamp
Hope to cooperate with you.
Lampdeng Co.,Ltd. (Guangzhou, China) is founded in 2000, is a major supplier of projector lamps
www.Lampdeng.com
I have a yellow spot on my Hitachi cpx10000 projector.
the Lcd panels are fault
or
the polarizer isfault
www.Lampdeng.com
What could have happened to the projector to get a large blob that changes shape and is purple colored. Like an amoeba that grows and moves around.
Font strokes are not cleaned
Black silk font is not black enough
reason:
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
My hitachi A120n projector has no power light checked internal fuse and ok .
two reason:
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
Hitachi projector cp-wx3041wn problem Power & temp light on ? How to solve
You should clear the air filter
and reset the air filter timer and the lamp timer
menu-advance-option-reset the air filter
menu-advance-option-reset the lamp filter
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
Posted on May 31, 2019
Hitachi cp-rx60 not powering Temp led light blinking red non stop what could be the problem
you should clear the air filter
Skype:
[email protected]
Email:
[email protected]
Email:
[email protected]
