20 Most Recent Acer P3250 DLP Projector Questions & Answers
Unlock code for samsung mobile
What is Samsung Mobile Phone model?You can get the Free Unlock code for OLD samsung phones at here Unlocking4free.com/samsung-unlock-tool and Unlock it step by step.
3/21/2019 2:45:33 AM • Acer P3250 DLP... • Answered on Mar 21, 2019
2answers
Acer P3150 lcd projector password-locked
I found a solution that worked for me: 1. Turn on the projector2. Press "Power > Left > Left > MENU" (Opens the system menu)3. Choose "RD Menu"4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops)5. Turn on the projector again and it should word again
11/12/2017 6:06:50 PM • Acer P3250 DLP... • Answered on Nov 12, 2017
3answers
Acer projector P3150 locked with passwd
Read some Acer manual and it says:
Administrator Password
The "Administrator Password" can be used in both the "Enter
Administrator Password" and "Enter Password" dialog boxes.
• Press "Play" to change the "Administrator Password".
• The factory default of "Administrator Password" is "1234".
If you forgot your administrator password, do the following to
retrieve the administrator password:
• An unique 6-digit "Universal Password" which is printed on
the Security Card (please check accessory in the box). This
unique password is the number which will be accepted by
projector anytime no matter what the Administrator
Password is.
• If losing this security card and number, please contact with an
Acer service center.
10/2/2016 12:33:47 AM • Acer P3250 DLP... • Answered on Oct 02, 2016
I have a acer P3359 DLP projector and trying to unlock it but remote seems to not work. They have new batteries
If you wish to get some details; check the site linked here. Pull up older posts... http://electro-medical.blogspot.com/
6/14/2016 3:18:05 PM • Acer P3250 DLP... • Answered on Jun 14, 2016
We have an Acer P3250 projector that keeps prompting for a password upon start-up. However, when we enter the security password provided with the unit, it says it is "invalid".
Found an earlier suggestion on this site if you don't have the provided password and also already tried 1234. 1. Turn on the projector 2. Press "Power > Left > Left > MENU" (Opens the system menu) 3. Choose "RD Menu" 4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops) 5. Turn on the projector again and it should work again Acer P3250 will not acccept password
4/26/2015 8:32:26 PM • Acer P3250 DLP... • Answered on Apr 26, 2015
My Acer P3150 projector is
3. Choose "RD Menu"
5/3/2013 6:06:40 AM • Acer P3250 DLP... • Answered on May 03, 2013
0answers
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
12/22/2009 1:58:08 PM • Acer P3250 DLP... • Answered on Dec 22, 2009
Acer DLP projector x112. Do not turn on, fan stop, power button blinking red/blue.. please help
I had the same problem with my acer x112 , and after checking everything i found out that the problem was the Color Wheel (not necessarily being broken) , it looked new but it was the problem , hope this helps
2/13/2024 5:17:47 PM • Acer Office... • Answered on Feb 13, 2024
2answers
Acer aspire es 15 boot device missing
Great Information sharing .. I am very happy to read this article .. thanks for giving us go through info.Fantastic nice. I appreciate this post.Controle d'acces Maroc
10/5/2022 4:53:16 PM • Acer Office... • Answered on Oct 05, 2022
2answers
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:Canon waste ink tank problem.1. Change the waste ink absorber2. Reset waste ink tank counterGo to the service menu;1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.NEXT2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.NEXT3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode. NEXT4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.NEXTEach time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.NEXTHit 4 times for waste ink counter reset.The number of the Reset button pressing LED 0 time ... Green Power off1 time ... Orange Service pattern print 2 times ... Green EEPROM print 3 times ... Orange EEPROM reset (EEPROM reset)4 times ... Green Waste ink counter reset On the end press POWER button to exit .FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
4/12/2021 12:37:51 PM • Acer Office... • Answered on Apr 12, 2021
Have problems with projector acer serie h5360 IR remote controls do not work.
HI recently repair online just few minute after your problem solve you can visit my site https://www.epsonprintersupport247.com/steps-to-fix-error-code-0x10-of-epson-printer/
5/14/2019 7:11:49 AM • Acer Office... • Answered on May 14, 2019
Acer P3250 DLP Projector Logo
32 questions posted
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Office Equipment & Supplies
Most Popular Question
acer p3150 lcd projector password locked
  • Office Equipment & Supplies
